Can't Log Fuel Trims
Old Aug 14, 2015 | 11:28 AM
lancerrally45's Avatar
According to your last statement.... Something higher then what you are running, haha.
I cant seem to find my roms. What do you mean pulling out your car? Why are you in open loop to begin with at that low load?
Old Aug 14, 2015 | 11:41 AM
ridenrunwv's Avatar
I guess I need to raise my load for closed loop at low RPM even higher. That or throttle position. I'm going open loop when I ease off the clutch to pull out at low RPM. My scaling is messed up still. Cruise is perfect but idle was - 12.5. I was looking at O2 feedback and not low trim when I said idle was within +-2.5.
Old Aug 14, 2015 | 12:34 PM
Hm weird...
I would say revert all values and following the following link"
https://www.evolutionm.net/forums/ec...ched-roms.html
Old Aug 14, 2015 | 12:47 PM
ridenrunwv's Avatar
I don't have a good, working tune to convert from MAF to Speed Density. That would have made this process easier.
I had a tune that was running great but really rich at idle and cruise . A shop made it for me remotely. They forced open loop and did not mess with the injector scaling so I was really wanting to get the injectors scaled properly and let the car run in closed loop.
Old Aug 14, 2015 | 12:54 PM
Ahhhh, poop.
I wonder if you were able to take their open loop tune, place it back in, scale the injectors to 800, then scale up the whole VE table to come in align with the wideband. May work. Just thinking of ideas.
Old Aug 14, 2015 | 01:14 PM
ridenrunwv's Avatar
I'm wondering how accurate it all is now. They got my WOT dialed in very quickly but that seems to be the easy part. I also noticed when first seeing what load I was hitting that the load didn't seem to match up. In my tune they set the 2 byte to 1 byte correction value to 2 and I had the default 1.2 in EvoScan. Tuner said he just goes off airflow and MAP and never messes with it like that anyways.
I've been trying to get the tune dialed in myself since the new cams because I just don't want a tune that I have no idea how to modify because of so many random things that I am confused about.
Old Aug 17, 2015 | 10:59 AM
This is why when I tune, I start off a base map. Never work off of someone else's tune. My opinion.
Old Aug 18, 2015 | 08:31 PM
ridenrunwv's Avatar
I finally did this and got everything dialed in nicely in much less time than I spent messing with what I had before. Does it seem reasonable that S3 cams would have a VE in the 50s at idle? That's the biggest thing that really has me question what I did but it seems to work out great that way.
Old Aug 19, 2015 | 01:30 PM
Yeah, I think when I had my S2s it was around 45-50 at idle.
Old Aug 19, 2015 | 01:45 PM
ridenrunwv's Avatar
Thanks again for your help. I ended up taking commonly posted scaling and latency values and dialing in my VE table using them. I didn't see any other way without having a known good VE table.
Old Aug 20, 2015 | 06:19 AM
Doesnt someone have a VE excel sheet table for doing WOT pulls? Or is this my dsm I am thinking about. I totally forget. Made my life a million times easier.
Do run, plug in datalog, it will spit out a new VE table, copy paste, done deal.
Old Aug 20, 2015 | 07:19 AM
ridenrunwv's Avatar
Sounds pretty cool. I didn't have much trouble with the WOT part but just trying to hit every load and RPM for cruising. I forced open loop and that helped me dial it in better. Still not totally happy with it but I'll fine tune it later on.
3gEclipseTurbo
Jan 28, 2010 01:41 PM
alicea8541
Jun 9, 2009 07:47 PM
UndieStainz
AEM EMS
16
Sep 28, 2006 03:50 AM
