XML Ralliart
Old Oct 2, 2015 | 12:07 AM
lexa609's Avatar
XML Ralliart
Good day! I write through the translator(
car galant fortis ralliart 4b11t ,td04hl
Through ecuflsash considered firmware ,but not a single Xml file is not approached.
Where to get XML ?
How to know the ECU ID?
I put the turbo motor in the Lancer MT .
since SST I don't have any then it is hanging error, as you can turn them off ?
File Type: rar
Old Oct 2, 2015 | 12:22 AM
lexa609's Avatar
How to disable DTC U0101, P1590 ?
Or need to use the firmware from EVO MT ?
Old Dec 8, 2015 | 06:11 PM
Wanchai Panpron's Avatar
ECU ID is 53590009.
at adress 5002a
Old Apr 8, 2016 | 06:13 AM
ZZZ's Avatar
ZZZ
Write normal working ROM for MT.
Old Apr 9, 2016 | 05:30 AM
Beeble's Avatar
So you put a Ralliart motor and turbo in a Manual lancer...
and using the ecu from the Lancer or from the Ralliart?
you need to put a RA or Evo ecu in it to get it working properly
bench flash an Evo MT rom on it (53040010) and tune from there
If you use the lancer MT ecu your mivec will not work when you use the evo rom. not sure why, but it doesn't work.
Old Apr 9, 2016 | 11:55 AM
lexa609's Avatar
The firmware that I posted is the firmware from Ralliart SST
XML I have long found fault off by SST I failed.
I took the firmware from Evo TephraMod v1 X MT rom id 53040010.
At the moment everything works fine.
The spec sheet of my car.
ENGINE 4B11T
turbine TD04H
All-wheel drive outlander XL
Gearbox MT Outlander XL
ASC 352 block
Custom under hood wiring
Fuel system EVo X
Exhaust system Evo X
The engine control unit Ralliart
In more detail, but only in Russian about my car is here
https://www.drive2.ru/r/mitsubishi/1137146/
Old Jun 7, 2016 | 11:25 AM
RALLInspired's Avatar
Evo firmware will cause even more DTC. I can disable all codes in outlander, Lancer, RA, Evo X, etc Mitsubishi CAN ECUs...
Old Jun 7, 2016 | 12:58 PM
lexa609's Avatar
Thank you !
With the errors figured out,the car is configured and pleases the owner.
Firmware is from Эво10 MT tephra V1
nandoliver
Jun 3, 2025 04:11 AM
Andrewstep
Jan 20, 2017 01:41 PM
crak
Dec 20, 2012 03:20 PM
