ID 1300cc
Old Oct 3, 2015 | 03:44 AM
mines5's Avatar
Question ID 1300cc
Hi every one,
Any one using id 1300s on evo 7/8/9 pump gas ?
i am looking to buy a set . can i get the data for id 1300s for linearization table ? any one tested them yet ? scalings and latencies ???
Please share your suggestions, experiences.
Old Oct 3, 2015 | 05:00 PM
mrfred's Avatar
You could try asking ID to provide you the linearization data. They've measured it on all their injectors. Just a matter of them putting it in the correct format for the Evo 8/9/10.
As far as scaling goes, I bought a set a while back. Before I installed them, I had them flow tested by a local shop that reported flow rates that were only about 5-6% better than my FIC1100s. That was quite surprising, so I sent them off to RC Engineering and got the same result. After a bit of digging, I found that a few seasoned tuners that had a similar experience. I ended up returning them and buying FIC2150s, so I don't have any actual scaling values, but they should be pretty close to what's been posted for FIC1100s.
Old Oct 4, 2015 | 12:39 AM
mines5's Avatar
Thanks for your valuable feedback mFred.
Being neutral and not being cynical, one should expect more flow with that extra 200cc . May be they perform better on E85 and less so on pump gas. looks like i have to dig more deeep.
Old Oct 4, 2015 | 01:06 AM
mines5's Avatar
Ok, i looked at FIC 1800 cc bluemax injectors which will cover the desired fuel requirement and have
a price difference of 335$ ..
why there is such a big difference in price compared to id 1300s ? low z vs high z or the all fuel compatibility advantage ?
Old Oct 4, 2015 | 09:46 AM
mrfred's Avatar
I was surprised too by the minimal flow rate difference. There won't be any improvement in the difference for E85.
I wouldn't do a low-Z injector above maybe 1200 cc/min unless you are on very tight budget or don't care about idle/cruise. They are old technology and are too hard to get to behave consistently under idle/cruise. Try the FIC1650s or maybe the new ID1700s. Or even the FIC2150s - after I got them dialed in, they are the best performing injector I've tried for everything from idle to WOT, even on pump gas.
Old Oct 4, 2015 | 09:56 AM
ridenrunwv's Avatar
Low to mid 500s to the wheels is around 90% duty cycle on E85 for me. Just to give you an idea of ID1300 on E85.
If I had researched it more I probably would have just gone ahead and gone with FIC 2150s and then I would have had room to run a bigger turbo or whatever if I decided to. People seem to get great drivability on the 2150s so might as well.
Old Oct 4, 2015 | 07:09 PM
mines5's Avatar
Mrfred, did 1650s came with connector kit for evo 8 since they are high z ? or they are just plug and play.
I understand , how critical it is to select a proper injector which gives both idle, cruise and top end performance. MrFred if i order 1650s can you please share some low pulse width mS data with me ?
Old Oct 4, 2015 | 08:04 PM
mrfred's Avatar
The 1650 is PnP. I've already posted the linearization data.
Old Oct 4, 2015 | 11:16 PM
kaganader2's Avatar
Registered User
I've heard this a few times in different forums but when I got a set of 1300cc flow tested they all flowed an average of 1294cc, and dropped a car that was at 98% IDC on 1000cc to 77% IDC on 1300cc, no change to fuel pressure or boost.
That is my experience with just one set of ID1300cc though.
Old Oct 29, 2015 | 01:55 PM
Pal215's Avatar
It's a shame that they don't perform as well as the FIC's. These ID's have a full stainless steal internal construction. It would have made them a great choice for all fuel types in the long run.
-pal215
Old Sep 5, 2017 | 06:41 AM
dillons13's Avatar
Hey
Hi every one,
sis u get the scaling for these injectors for evo 8 9?
can u share pls
Speed Element
EvoX 'For Sale' External Engine / Power
26
Feb 24, 2011 05:34 PM
DeatschWerks
Aug 3, 2010 09:11 AM
maperformance
33
Jul 26, 2010 03:43 PM
DeatschWerks
42
Jul 8, 2010 08:21 AM
maperformance
Jun 2, 2010 01:58 PM
