definition files for map sensor scaling
Old Dec 11, 2015 | 02:49 PM
rxtec's Avatar
Exclamation definition files for map sensor scaling
I really have look all over the place, so i am trying something else.
I can get to see this information on my ROM.I am using the 9653xxxx patch with mods v7.
can someone please post this information so i can add this to the definition file so i can change this setting.
the reason i am using a different map sensor that the ROM uses and I need to re calibrate this settings.
I will gladly appreciate the help
addicional info:
I had read a ton and I ran out of ideas.
Here was suppose to be me life saver but the definitions does not show in the webpage and the links are not working
https://www.evolutionm.net/forums/ec...y-patches.html
Please
Old Dec 11, 2015 | 02:51 PM
rxtec's Avatar
i cant get the option "MAP sensor" on the ecu flash, just in case its in developer mode all ready
Old Dec 12, 2015 | 10:36 PM
CDrinkH2O's Avatar
XML for 96530706 attached. This include the MAP EGR test code and scalings.
File Type: xml
Old Dec 14, 2015 | 06:49 PM
rxtec's Avatar
thank you very much !I appreciate it
ofey
Lancer Engine Management / Tuning Forums
Nov 27, 2010 03:19 AM
Phoenix*
Jul 25, 2009 06:01 AM
BarryC
Feb 7, 2008 11:17 PM
Zamot
Sep 6, 2007 11:41 AM
