12' GSR Boost Tuning
Old Mar 2, 2016 | 04:24 PM
psfp's Avatar
Your boost curve is bouncing because you are getting too much boost (above your target values), so WGDC correction is kicking in. Your definitions look weird, like a mix of PSI and Load based boost control. What did you do to your definition file (XML)?
Why don't you use RAX patch to get faster logging and atmospheric baro compensation? Check it out:
https://www.evolutionm.net/forums/ec...m-patches.html
Old Mar 2, 2016 | 05:03 PM
kiddsm95's Avatar
This shows 1 thru 4. Sorry it's a pic from my phone, no internet on the train.
WGDC are set back down to 50%.
Does this look right?
As for my XML, I'm using the 58010005 ROM from Golden's site.
Originally Posted by psfp
In my opinion, you should:
1) Restore your Boost Error Correction values back to stock
2) Set all your Max Total Upward WGDC Correction vs TPS values to zero
3) Set your "boost target" tables a bit above your desired final curve
4) Reduce your base WGDC values
After that, SLOWLY increase your WGDC tables to achieve your desired boost curve.
Old Mar 3, 2016 | 01:27 PM
kiddsm95's Avatar
Looks much better after implementing changes 1-4 psfp suggested.
Log0059 (green) was the overboost I was having yesterday.
Log0063 (red) was after the changes 1-4 psfp suggested, plus I pulled timing in the areas I had knock.
Log0064 (blue) is tweaking the WGDC for a better boost curve.
Still more to do.
I appreciate everyone's help.
File Type: csv
BillSpec
AEM EMS
Jun 13, 2010 09:10 PM
JapanEvo4
Mar 19, 2008 06:18 PM
