ECUFlash Issue
Old May 23, 2016 | 08:35 PM
wreckleford's Avatar
ECUFlash Issue
Today I started having an issue with ECUFlash where it freezes up when I try to read the file off of my ECU. I tried multiple times with the same result. It doesn't freeze at the same point each time either. Sometimes at 5% read, sometimes at as much as 90% read but I couldn't get it to pull the file.
I tried a different ECU and the same thing happens. For the hell of it I tried to flash a different ROM onto the ECU and it hung. I then made a small change to the original ROM and flashed it and it worked but I still cannot read the ROM back off of the ECU.
Evoscan datalogs fine and the car starts fine without any error codes.
The car has been parked for sometime so I don't know if the car is the issue. The only other thing is that the computer was changed from Windows 7 to Windows 10 recently. I have tried compatibility mode to correct any issues here but that hasn't changed anything. Also re-installed ECUFlash.
I am using a Tactrix 2.0 and ECUFlash 143.30. It was a beta but i have been using it for literally 4 years or so without any issues. I am wondering if I should install the latest version of ECUFlash.
Let me know if anyone has any insight.
Thanks.
Old May 23, 2016 | 08:59 PM
Seems I may need to update to 1.44.
Old May 24, 2016 | 12:57 AM
Raceghost's Avatar
I'm on the latest release running win 8.1, no issues. Whats the Battery like on your car, if it's been parked some time? Could be that, or could be the old release of ECUflash your using with win 10. Either way, hope you figure it out.
Old May 24, 2016 | 03:17 AM
Fireescape's Avatar
Battery is probably a little bit to flat. Try sticking your battery on a charger and having another go. This happens to me all the time.
Old May 24, 2016 | 05:17 AM
Sorry, forgot to say that I tried it also with a charger connected to the car battery.
Old May 24, 2016 | 06:39 PM
BossEvoVIII's Avatar
Veteran: Marine Corp
I doubt you're locked out but you can give EcuUnlocker a shot.
Just leave it open with ecuflash
https://www.aktivematrix.com/blog/ak...ix-useful-info
Old May 24, 2016 | 09:37 PM
Tried that too.
I suspect it is a compatibility issue with Windows X. Have downloaded 1.44 but haven't gotten to try it yet.
Old May 25, 2016 | 03:25 PM
any updates?
Old May 27, 2016 | 08:03 PM
Got it resolved yesterday by installing 1.44.
Old May 27, 2016 | 08:06 PM
Got it resolved yesterday by installing 1.44. Thanks.
Done
Jan 12, 2009 11:01 PM
