Evo new build tuning woes
Old Jun 29, 2016 | 11:05 PM
Biggiesacks's Avatar
took another look at your log, you can see the ecu is calling for different injector duty cycles but the pulse width is stuck at that 1.28 value, which again im guessing is a hard limit that you will need to lower.
*** IGNORE this, its too late for me to be posting lol. Duty cycle is just a value calculated within evoscan and is not reflecting what i thought it was.
Last edited by Biggiesacks; Jun 29, 2016 at 11:13 PM. Reason: too tired to think right
Old Jul 11, 2016 | 11:56 AM
Alchem1st's Avatar
Bit of an update! Made some progress on this. Found out my wideband sensor was bad. Turns out that 14.7AFR is around 12.0 on the gauge so it's running super lean. Richening up the mixture got rid of the issue at first startup; but after the car warms up it falls on it's face. Something is being triggered in the ECU that's causing the issue. It's obvious if you look at the log.
Goes from a perfect 13.8AFR at idle to 17.0AFR! It falls off a cliff there. Really weird. Hoping some of the guys over at Lancerregister (or here) who know the Evo 5/6 ECU well can help me figure out what it is that's causing the issue.
Old Jul 30, 2016 | 01:23 AM
evo8vz's Avatar
scaling on e5/e6 ecu is different on injectors
BeastYamin
Sep 15, 2015 06:45 AM
MFactor
12
Feb 14, 2007 10:39 AM
dryad001
Jun 3, 2005 11:32 AM
PDXEvo
May 25, 2005 05:37 AM
