Lower Load Knock - We don't care?
Old Jul 15, 2016 | 07:11 PM
cmz's Avatar
cmz
So I was working on knock today after converting to Tephra v7.
I'm curious about "Knock Load (knock ignored below these levels)":
If I set those levels all to say 10, i get the following from making an lap around the block (staying out of boost, maximum values):
Is there are reason not to bother tuning out knock below the default levels in that table?
Old Jul 19, 2016 | 12:38 PM
ReidFletcher's Avatar
Looks like phantom knock. Log knock voltage, true knock counts usually register at 1.5V or above. Phantom knock won't spike voltage much or at all.
Old Jul 19, 2016 | 12:59 PM
lancerrally45's Avatar
Cylinder pressures around light load are significantly lower than when at higher loads. Meaning the stresses applied to the parts are also significantly reduced. I would ignore it. I believe my load is set to ignore anything below 100.
thedru13
Nov 3, 2014 08:58 AM
Crester
Nov 17, 2010 08:09 AM
