Introducing the Spark Cut patch, finally a solution for SST Boost of the line
Old Feb 16, 2017 | 12:05 PM
  #76
franzcars's Avatar
I need the mut table too. I wasn't expecting you to only send me those.
As a general note for everyone, if I'm making a custom one-off patch, I need as many deffs as possible,
Old Feb 17, 2017 | 11:05 AM
  #77
Hiram6g74's Avatar
Tell me if you need to define you something else, and thanks in advance
File Type: xml
Old Feb 23, 2017 | 07:06 PM
  #78
Hiram6g74's Avatar
Can you make it ?
Old Mar 4, 2017 | 04:08 PM
  #79
Solarwater's Avatar
Hi Franzcars, thanks for the patch, it is pretty cool!
I did find something that looks like it needs to be corrected. In the file for 55570006, it looks like the final table def is cut off. I finished the line using one of the other files as a template, and it seems to work fine.
Just thought I would bring it to your attention.
Old Mar 10, 2017 | 06:15 PM
  #80
veszett's Avatar
I wouldn't mind trying this patch on V3 53040310 if you can make it available.
Old Mar 12, 2017 | 01:50 PM
  #81
franzcars's Avatar
Thanks, I'll fix it and push it with the next update!
What's the original rom for your car? I see you're in the US but that's a EDM rom, if so the patch will not work unfortunately
Old Mar 15, 2017 | 03:57 PM
  #82
franzcars's Avatar
Big update, about 10 more patches in the first post
Old Mar 18, 2017 | 06:31 PM
  #83
GP148's Avatar
has anyone had any issues using Tephras launch maps feature with this upgrade. I am now trying to use both features together however, i am unable to have the launch maps engage. the timing and fuel targets are not changing when i try and launch. I have selected the max launch speed at 5km, not sure if i am missing somehing else
Old Mar 25, 2017 | 08:06 PM
  #84
Hiboost's Avatar
Is this on an MR? If so you probably want to change your RPM to 4500 and test from there. On a GSR you would need to raise the normal stationary limiter to something like 6000 be able to hit the spark cut limiter 5500. At least that is the way I'm reading this from the 1st page:
“Recommended” settings:
  • With the Fuel cut rev limiter set to the default 7599 and the Divider set to 1.11 the rev limiter will be just more than 7500
  • On a 5MT car the stationary can be set to the default of 5500, however the stationary rev limiter under limits will need to be raised.
  • On a SST car it needs to be set below the throttle closure RPM for the launch control, in testing we found 4500-4600 to be the most effective setting. On a stock 2.0 with a 5858 we built 3-5 psi depending on outside temperature, with no additional tuning.
Old Mar 27, 2017 | 04:07 PM
  #85
GP148's Avatar
Thanks for your reply , however, I was in referring to the launch maps within Tephra v3. I did initial tests for this patch and am aware of its ideal settings, however, I am unable to have both Tephras launch maps work at the same time as this patch being enabled. It is a MR and I would like to take advantage of the launch maps function within tephras build. Do you have any suggestions as to what I could be doing wrong
Old Mar 27, 2017 | 08:13 PM
  #86
franzcars's Avatar
Are they enabled by default now? I know for awhile he did not have them enabled by default on the MR's
Old Apr 11, 2017 | 04:55 PM
  #87
trinibt65's Avatar
Very interested in doing this but will it work on a 2010 ukdm fq300...ecu locked from factory by ecutek unfortunately...so is there anyway my tuner using ecutek can program this in?or can it be done using the instructions of the first post?
Old Apr 12, 2017 | 07:30 AM
  #88
franzcars's Avatar
Unfortunately this is only for EcuFlash as Ecutek does not let end users to change the code as is needed to do for this patch.
Old May 1, 2017 | 02:07 PM
  #89
franzcars's Avatar
The patch is finally making its rounds
https://www.facebook.com/MyEvoo/videos/1345454965530884/
Old May 23, 2017 | 04:18 PM
  #90
sleandro's Avatar
Patch my ROM
https://www.facebook.com/MyEvoo/vide...5454965530884/
Hello!
I'm trying to find the instructions to patch my ROM, but haven't found it yet. My ROM ID is 58640002. It's a 2011 lancer Ralliart. Would you help me patch it? What do you need?
Thanks mate!
