Introducing the Spark Cut patch, finally a solution for SST Boost of the line
Old Sep 28, 2017 | 11:23 AM
  #106
franzcars's Avatar
Originally Posted by jakgal04
Does anybody have an issue where the spark cut feature is breaking their spark plugs? I've had two plugs now with broken ceramics.
How aggressive is your timing? I guess it's possible that it could crack the plugs, but i doubt it since the ignition happens outside of the chamber with enough negative timing
Old Sep 28, 2017 | 12:58 PM
  #107
jakgal04's Avatar
Originally Posted by ETS Michael
Yeah, I run negative 15 timing and add some fuel. Are you making sure to add fuel ?
- Robert
I had timing at -10 and plenty of fuel. I'll try lowering the timing some more and see how that works.
Old Sep 28, 2017 | 01:01 PM
  #108
jakgal04's Avatar
Timing isn't really aggressive, and even if it was, you're right. It shouldn't have much of an impact since it's mostly outside of the combustion chamber. I've decided to disable the patch for now until I have more time to log and adjust lol
Old Nov 21, 2017 | 03:48 PM
  #109
llabmik2's Avatar
Have you done anything for the 2011 Ralliart 56940007
Old Nov 21, 2017 | 08:34 PM
  #110
franzcars's Avatar
Yes I have
File Type: txt
Old Nov 22, 2017 | 05:28 AM
  #111
llabmik2's Avatar
Yes I have
Thank you sir!
Old Dec 3, 2017 | 10:29 AM
  #112
danneg83's Avatar
Anyone here that sits on fully functional "launch map" thats suitable for a pretty stock RA? My setup is boostpill and open filter. And of course reflashed tranny And I´m also on tephra v3.
Old Dec 6, 2017 | 01:20 PM
  #113
strykr's Avatar
Veteran: Canadian Forces
I plan to hopefully have this by the end of the weekend, so long as work doesn't get involved. I will let you know if I get it working, unless someone gets back to you sooner.
Old Mar 10, 2018 | 02:03 PM
  #114
kozmic27's Avatar
the download link for the xml is broken
Old Apr 24, 2018 | 12:14 AM
  #115
Ian0611's Avatar
This.
I went to EvoXforums.com and was able to download it there though.
Old Jul 7, 2018 | 02:31 AM
  #116
martin366's Avatar
Unhappy Problem
Hi!
Thanks for your effort creating this awesome patch.
But i have problem with it.
'11 EDM SST
Stock rom 56920006. Installed 56920008 Tephra v3 + 0008 patch.
Stationary rev limiter works but it uses base timing and fuel maps instead of tephras launch map.
How to fix it ?
Old Jul 9, 2018 | 08:57 AM
  #117
franzcars's Avatar
Originally Posted by martin366
Hi!
'11 EDM SST
How to fix it ?
Send me an email and I can send you the patch to make it work with the launch maps
Old Jul 27, 2018 | 08:09 PM
  #118
aj6828's Avatar
i have a 2008 JDM evo x SST on 52370028 can you make me a spark cut patch, please .. Thank you so much
Old Dec 27, 2018 | 11:50 AM
  #119
prozak's Avatar
I have a question, I have a 2009 ralliart USDM and I added the xml and setup the rom. Does everyone using this patch have a flashed SST in the ralliarts ? I flashed mine and have S-sport mode, but for the life of me I cant get the launch mode to work. I though I read some of the 2009 had an issue with launch, but I see many 2009 that are using launch mode, with this spark cut fine. Am i missing something ? I have tried a regular rom, i tried it on tephramod V3 ... my car is in S-sport mode, ASC off , foot on the brake, mash the gas and it either does 1 of 2 things, revs right by the stationary limit or if i press the gas a little slower you can feel the clutches start to grab which is not what we want right ? any advice here would be great... been trying things for weeks with no luck.
Old Feb 22, 2019 | 11:34 AM
  #120
BLACKzj52's Avatar
I want to bump this. I know this is for X/RA's but any chance of this happening for a stock 8/9 ECU??
