Evo scan 2.9 vs Ecu Flash High Octane Maps
Old Nov 6, 2016, 03:04 PM
4b11slayer's Avatar
Here is my map so far.
Old Nov 6, 2016, 03:08 PM
4b11slayer's Avatar
This is were im at
Old Nov 6, 2016, 04:12 PM
Biggiesacks's Avatar
as your making changes though your flashing it back and seeing changes in your logged values right?
Old Nov 6, 2016, 04:37 PM
4b11slayer's Avatar
Yes i started by doing part throttle pulls then gradually raised rpm eventually to redline making adjustments and re logging. Im not just blindly throwing numbers in tje octane map.
They just seem soo lean to me. I guess i should keep reminding my self that they are just a number.
Im gonna be switching to a sd rom here soon as i get this tune pretty perfect.
As far as timing goes i havent made any adjustments since my tune.
Im seeing about 7 degrees at peak torque. I wont touch those yet need more reading.
Thanks for the input Biggie Sacks
Old Nov 6, 2016, 04:45 PM
Your Welcome, I had to ask because you never know, i work in IT and its bad to assume people do things the way you think they are doing them. The fuel map is just so setup dependent that I would be worried to even give an opinion on what the values "should" look like. As long as your changes are producing the predicted results, and your AFR's are moving in the direction you want them to then your on the right path.
4b11slayer (Nov 6, 2016)
Old Nov 6, 2016, 04:53 PM
4b11slayer's Avatar
Is The High Octane Ignition map the same deal?
Or are target degrees actual degrees?
Old Nov 6, 2016, 04:56 PM
the target degrees are the actual degrees the engine will run as long as there is no knock and it hasn't had the octane number degraded causing it to run off the low octane maps. There are some exceptions though, like at idle it will adjust the timing to maintain idle stability.
Old Nov 6, 2016, 05:03 PM
4b11slayer's Avatar
Alright that seems to wrap up tonights questions.
Im sure ill be posting alot.
Hope to get this tuning thing down. I have like 4 friends who need a tune and want me to do it but im like woaaah. Heree im still a green bean.
Old Nov 6, 2016, 05:16 PM
Happy tuning Keep em coming
Jdubya
Aug 13, 2013 04:46 AM
turbotoy
Jan 27, 2013 10:42 PM
Raceghost
Dec 17, 2009 10:55 PM
EVOXSILVER
14
Jul 10, 2009 05:46 PM
evil mechanic
Mid-Atlantic Region
Jul 21, 2006 04:35 PM
Quick Reply: Evo scan 2.9 vs Ecu Flash High Octane Maps
