Evoscan reading zero- ECU ID0000
Old Apr 28, 2017, 11:38 PM
mr.k's Avatar
Hopefully some of you Evoscan guru's can help me out.
I'm running into an issue with evoscan not reading the ecu correctly. When I go to start a log, all of the variable values are zero or "x" in each function, is being read as zero. I have done multiple fresh installs of Evoscan and the drivers, yet nothing seems to help. I am not sure if this is a compatibility issue or what. I am no expert by any means with evoscan, so please guide me in the right direction if I am out of place.
Attached pic shows exactly how evoscan looks when I try to log:
The tactrix cable is new and fine; it can pull the rom in ecu flash with no problems.
My computer:
Windows 10 64 bit
Two generic USB hubs
One AMD USB 3.0 hub
Still get the same issue no matter what port is used.
Thanks in advance
Old May 1, 2017, 03:51 PM
mr.k's Avatar
BUMP
I wanna get some logging done
Old Jul 26, 2017, 10:42 AM
mr.k's Avatar
Bump.. Nobody knows how to fix this?
Old Jul 26, 2017, 12:00 PM
4b11slayer's Avatar
Has to be some sort of scaling issues. Look how coolant temp is 300+ degrees.
Old Jul 26, 2017, 01:22 PM
mr.k's Avatar
Not sure what is up with the coolant temp but everything else reads 0 for x. All the equations values represent 0 being the input.
Any help is appreciated though!
Old Jul 26, 2017, 01:49 PM
4b11slayer's Avatar
what cable is it? your hooked up to both plugs?
Old Jul 26, 2017, 02:08 PM
mr.k's Avatar
Tactrix 1.3u cable. This is a relatively new cable.
Both are plugs plugged in, ecu flash works fine, I can trigger any actuator in evoscan... Just no logging
Old Jul 26, 2017, 02:36 PM
Klaiceps's Avatar
I'm not near my laptop to see Evoscan but maybe try selecting a different ECU in the drop down list.
silverstream
Aug 20, 2011 05:16 PM
DrivelineSales
May 13, 2010 02:35 PM
Sam@DriveLine
Evo 'For Sale' Suspension / Brakes / Handling
43
Jan 8, 2009 02:19 PM
EVO8LTW
Nov 7, 2008 11:24 AM
Quick Reply: Evoscan reading zero- ECU ID0000
