Load logged in evoscan and timing numbers
Old Jun 13, 2017 | 03:44 AM
eTiLiKo's Avatar
Test subject an EVO X MR SST 53050109 (V1 53050109) compared to the same car with 53050312 (V3 53050312).
The car was dyno tuned on a 0109 rom, using Mode 23 "Load" as reference for everything.
Now I switched to 53050312 copying every table and setting from the old rom.
I made a 4th gear log to see if something is wrong, and I can see that timing numbers are higher at high rpm than before (+2 degrees).
I can see that Mode23 2010 doesn't have the generic Load as before, but Load (fuel), Load (mivec) etc.
I imagine that "Load (fuel)" is the same as the old "Load".
But my question is : in 0312 is load calculated differently than in 0109? More in general, is on 2010+ load calculated diferently than before? Because is a fact that now I have higher timing numbers. (But now weather is hotter than when the car was tuned)
redSLed
Jan 9, 2017 05:22 PM
JorgeYaHeard
May 22, 2013 10:04 AM
eastxcelerate
Mar 19, 2009 07:33 PM
merkzu
Oct 2, 2007 06:49 PM
