lean spool afr
Old Sep 4, 2017 | 08:38 PM
kika747's Avatar
lean spool afr
hey guys wondering as a general rule of thumb what afr i should be looking at as i am comming on to peak boost e.g. my peak boost is set at 20 psi so at 5 psi should i be 13.0 10 psi 12.50 15 psi 12.0 20 psi 11.80? any answers much appriciated
Old Sep 4, 2017 | 11:23 PM
4b11slayer's Avatar
Im running 12.8 spool up by 10psi im 12.0. 11.8 30 psi to redline on e85 of course.
Old Sep 5, 2017 | 03:56 AM
kika747's Avatar
Do you think it would be safe to run same afr as what you said you do on e85 or a bit richer because pump gas dosnt burn as cool as e85
Old Sep 5, 2017 | 05:58 AM
ronaldo9's Avatar
Richer in my opinion. What do your plugs look like? Also are you experiencing knock?
Old Sep 5, 2017 | 06:48 AM
4b11slayer's Avatar
Pump gas should be 11.2 full boost.
Old Sep 6, 2017 | 05:10 AM
kika747's Avatar
I'm running 11.80 @ 14 psi full boost on my gt3582r and my plugs look great. So I'm thinking to get this gt35 to come on a bit sooner I should be running 13.0 afr @ 0 psi 12.50 @ 5psi 12.0 @ 10 psi and 11.50. @ 14 psi full boost what you guys think atm it's 12.50 @ 0 psi and and from 5 psi to full boost 14 psi it's 11.80 and seems very laggy
Old Sep 6, 2017 | 06:12 AM
ronaldo9's Avatar
What does your timing look like? In my experience my gtx3582r spooled better with richer afr's but perhaps my timing is more aggressive than yours.
Old Sep 7, 2017 | 08:09 AM
kika747's Avatar
I'm running 7* from 3-3500 rpm 9* at 4000 11 at 4500 13* at 5000 and 5500 onwards 15* on 98octane pump unleaded so at peak Boost 14Psi I have 7*-8* timing at 3500-4000 rpm
Old Sep 7, 2017 | 08:11 AM
kika747's Avatar
So What do you think I can squeeze some more timing in or is it getting a bit dangerous putting more than what I have now
Old Sep 7, 2017 | 08:14 PM
ronaldo9's Avatar
I could never run more than 4* at peak boost without knock which was around 25 psi on 93 octane and i wouldn't run more than 11* uptop 13* maximum but I have stage 1 cams. And I strive to hold an 11.2 afr. I usually get the fuel curve where i want it and then play with the timing. Be careful check your plugs and monitor the knock.
Old Sep 10, 2017 | 07:45 AM
4b11slayer's Avatar
I run *18 uptop on e85 tho
Old Sep 10, 2017 | 04:17 PM
RazorLab's Avatar
Why on earth are you only running 14psi with a gt3582r? It feels laggy because you aren't running any boost.
Old Sep 11, 2017 | 05:40 AM
kika747's Avatar
Sorry I forgot to mention it is an rb30 engine in a vl turbo but posting here because I used to have an evo 6 and you guys know your stuff this has been the most knowledgeable forum to me and I have learnt most of the stuff I know from here so all Imput from everyone much appreciated
richardjh
42
Apr 20, 2011 05:21 PM
evonut270
Nov 7, 2009 11:24 PM
Boosted GP
Sep 22, 2009 08:22 AM
Appauldd
Jul 4, 2009 07:42 AM
RoadSpike
Sep 30, 2007 05:42 AM
