2015 GSR, weird error when reading
Old Mar 11, 2018 | 04:52 PM
BigT's Avatar
Going to admit right now, its been a while since I've used ecuflash....
So I'm trying to read the map on my 2015 GSR for the first time. Downloaded newest version. Have my openport 2.0 cable. But, then this happens..
Old Mar 12, 2018 | 05:01 AM
BigT's Avatar
What strikes it odd for me the most is the /read_evo5.xml. Does anyone have the 2015 XML definitions? Golden's site seems to be down.
Old Mar 12, 2018 | 06:46 AM
RazorLab's Avatar
You are using the wrong setting, make sure you use Mitsubishi CAN in ECU type.
You can grab the XML from my site here: http://norcalmotorsports.org/users/b.../ROMs/XML/Evo/
Old Mar 12, 2018 | 07:03 AM
BigT's Avatar
Thanks for the XML!
Ecuflash now has settings? Shouldn't it know what ECU I have if the correct XML is there?
Old Mar 12, 2018 | 10:15 AM
RazorLab's Avatar
Originally Posted by BigT
Thanks for the XML!
You've always had to select which ECU to connect to. Evo 8, Evo 9, Evo CAN, Subaru, Subaru CAN, etc.
Old Mar 12, 2018 | 08:36 PM
BigT's Avatar
Thanks, Bryan. I loaded up your XML and was able to open a 2015 bin file I found online. I'm not near the car now, but will give it a go tomorrow. Thanks for the reminder on choosing which ECU. For some reason, the window didn't pop up when hit "read" and my long lost memory didn't kick in. lol
Do I need a new def to get Evoscan to work? The logger turns on, but I'm getting pretty wacky results for some logged items.
Old Mar 15, 2018 | 04:48 PM
BigT's Avatar
Ecuflash is working great. Thanks again, Bryan.
But evoscan is not. Using rom 59580004, enabled mode 23 and flashed car. None of the mode 23 evoscan ecu settings seem to give numbers worth a damn. This was on v2.7. Bought and downloaded v2.9 and same issue. Tried to find new def, but everything is leading to Golden's site which looks like has been down for a while. Anyone have a file they can share?
Autocross opening day is Sunday and need my STU car tuned to be competitive.
Old Mar 15, 2018 | 05:00 PM
RazorLab's Avatar
Enable RAX logging. Way faster anyway.
Stradale
Oct 22, 2009 06:41 AM
JKD
Aug 29, 2009 05:20 PM
Stradale
Jul 28, 2009 04:48 PM
zwampy
Apr 3, 2007 06:48 AM
