Recent tune reading 9+ knock..
Old Jul 12, 2018 | 02:25 PM
blackline's Avatar
5 Year Member
Recently got my car tuned and I've been getting knock on the top of 3rd and 4th. I posted some pics of the tables from the tune. Does it seem off or super aggressive?
Ill post logs this weekend after I get the coolant leak issue resolved.
Mods:
Ported head
Ported Intake Mani
Ported Exhaust Mani
GSC S2's
Springs/Retainers
Wiseco Pistions
Manley T Rods
1000cc Injectors
COP
BBK FULL Turbo
Megan 3in turbo back
Car made 400hp and about 350tq.
Old Jul 12, 2018 | 06:55 PM
LetsGetThisDone's Avatar
What fuel?
How much boost?
What load is it hitting?
Really need a datalog to say for sure...
Old Jul 12, 2018 | 07:05 PM
Abacus's Avatar
I can't recall where the BBK full comes in size and pump fuel power. How much of the boost?
Somewhat taboo to post a tuners map . That timing map is in the ball park at the higher load levels.Less is more in the end. Its always a good idea to check what actual timing you are getting with a light though.
You could try to take some timing out below 5500 as a start. It’s easier to prevent knock from happening then try and stop it once it starts.
A built engine can make more noise then a stock one, some times the knock filters need to be adjusted . Maybe one of the reasons the knock light is set to 8. Its a good idea to do that at low smoothing on a dyno to see exactly good/bad the engine is running when adjusting the filters. This will let you figure out real knock vs phantom knock. Running it on a dyno vs VD will also allow you to know exactly what it makes per degree of timing.
An hour on the dyno is money well spent IMO. Controlled environment and you can see what the engine is doing.
Old Jul 12, 2018 | 08:01 PM
blackline's Avatar
5 Year Member
It's on 93oct and 26psi's.
I removed the maps as I didn't know it was frowned upon. Once I have the logs on Sunday I'll post them. Other than the knock the car runs smooth and very surprised on how SD drives at low speeds.
Old Jul 13, 2018 | 06:42 AM
26psi is very reasonable for 93 octane. It probably has too much timing somewhere. Need to see some WOT logs.
pizdets
May 9, 2016 06:12 PM
Z_Lancer_Man
Apr 15, 2016 09:27 AM
thedru13
Nov 3, 2014 08:58 AM
Crester
Nov 17, 2010 08:09 AM
MR
Sep 10, 2007 01:19 AM
