ECUFlash Blobbits Tables - Can't See Values?
Old Oct 21, 2019 | 07:26 PM
drb's Avatar
drb
I'm trying to apply this Force OBD Inspection Pass patch and I'm running into some issues:
https://www.evolutionm.net/forums/ec...us-mrfred.html
I can't see the values in these "Monitor Available/Not Available" & "Monitor Passed/Failed" blobbits tables? I'm hoping that this is a relatively simple question for someone.
Thanks in advance for your help.
Old Oct 21, 2019 | 10:20 PM
Dallas J's Avatar
Veteran: Army
I ran into this a long time ago and never got an answer as to how to fix it totally but the cause is typically windows scaling not working correctly with ECUflash. If you set it back to 100% you should see it just fine. Of course it might be tiny if you have a high res laptop you're using. In general, I try to stick to 1080 or 1440 laptop resolutions in general because the windows scaling issues are pervasive along a lot of different programs.
Old Oct 22, 2019 | 09:44 AM
drb's Avatar
drb
Thanks, but what do you mean by set it back to 100%?
Old Oct 23, 2019 | 01:57 PM
pisyakot's Avatar
incorrect scaling for the table
Old Oct 23, 2019 | 05:30 PM
drb's Avatar
drb
Thanks, can you point me in the right direction on how I fix this?
Old Oct 24, 2019 | 01:11 PM
drb's Avatar
drb
Got it fixed by using a different xml file.
Kishin
Jul 28, 2017 10:20 PM
alcrisulate
Feb 12, 2013 09:29 PM
ruhllatio
Feb 27, 2011 07:38 AM
Nate
Oct 26, 2010 09:11 PM
justchil
Oct 30, 2007 08:01 AM
