Problem since installing and tuning 3-port
So this issue has me stumped. Since installing a 3-port and tuning (just to standard at this stage) it i have been getting a wierd idle issue that often stalls the car and results in a p0100 (Maf sensor) fault (fault registers after car stalls).
Car is an Airtrek turbo. Runs a stock boost solenoid which i have disconnected and hooked up a 3 port instead.
3-port is not set to be active under 2000 rpm - It normally does a cycle when you first start the car but thats it. The 3 port is vented back to the intake post MAF.
The sequence usually follows:
Car is idleing like normal
3 port solenoid activates for around 1.5 seconds (appears random)
car immeadiately stumbles and stalls
Check engine light comes on with p0100 code
Any thoughts as to:
Why the solenoid is intermitently activating at idle?
Why activating at idle would cause the car to stall?
Any thoughts as to:
It sounds like same kind of duration as when the solenoid activates when you first start the engine.
I'm wondering if the solenoid is activating/starting up based on one of the threshold tables like engine temp (which is set quite low at 45 deg).
soderdna
Sep 3, 2016 11:22 AM
fengzhaoxi
Apr 3, 2010 10:54 PM
