Can’t read ecu tj Magna Sports
Old Dec 28, 2020 | 03:13 AM
Ppwheelswa's Avatar
read ecu tj Magna VRX
I have a tj Magna, a new tactrix, and downloaded ecuflash. I’ve got all the Magna XMLs I found online installed and a read template for vehicle type evo 7 gt or something like that. I tried the evo 9 vehicle type also, But it just does some sort of check for about 4 lines and says failed, not recognise. Tactrix is functional. Using Windows 10 notebook.
Last edited by Ppwheelswa; Jan 2, 2021 at 06:30 AM. Reason: Just wondering if you can delete this post, it’s my first and I’m not happy with it.
Old Dec 28, 2020 | 08:57 PM
OzAirtrek's Avatar
Originally Posted by Ppwheelswa
I have a 2002 3.5ltr tj Magna Sports 5sp auto. I have new tactrix, latest version ecuflash and ecoscan. I’ve heard the 512k ecu s on this model are hard to read. I’ve got all the Magna XMLs I found online installed and a read template for vehicle type evo 7 gt /Magna or something like that. And tried the evo 9 vehicle type also, But it just does some sort of check for about 4 lines and says failed, not recognise.. something. Tactrix is functional. Using Windows 10 notebook.
You will probably need to edit your read template. I havnt done a Magna but you need to find the correct memory model and read method for the car. You may have to edit the read template and try a few.
Old Dec 28, 2020 | 10:46 PM
Ppwheelswa's Avatar
which part of the template is that?
Old Dec 28, 2020 | 10:54 PM
Ppwheelswa's Avatar
Here it is
Old Dec 30, 2020 | 01:40 AM
Ppwheelswa's Avatar
Nothing like that has seemed to work. I think mabee it’s locked. It says something about FOFO1, FOFO2.. I have no idea how to unlock it. Tried to download ecu unlocker, but my internet security won’t have it.
Old Dec 31, 2020 | 05:47 AM
WytWun's Avatar
J series ECUs, auto or manual, are easy to read - you should be able to read the first 256kB of an auto just using the Evo 7/8 vehicle type (Evo 9 won't work for the J series ECUs). The Evo 7 GTA read template is required to read the full 512kB and access the trans tables though.
Did you get the Mitsubishi reflash adapter (separate purchase from Tactrix, included if purchased from Evoscan) and have it plugged into the reflash connector and OpenPort?
Magna/Verada ECUFlash ROM definitions and some documentation available from the ModifiedMitsubishi Github repo. There is also a thread for these on the AussieMagna forums.
Old Dec 31, 2020 | 07:21 AM
Ppwheelswa's Avatar
I have the reflash adapter. Does it need to be plugged into both at the same time?
Old Dec 31, 2020 | 06:39 PM
WytWun's Avatar
Yes
Old Jan 1, 2021 | 07:15 PM
Ppwheelswa's Avatar
Cool, thanks! Do you know if I can flash my car with any of the evo maps on evo scan?
Old Jan 1, 2021 | 07:32 PM
Ppwheelswa's Avatar
As evos are 6sp and turbo.
Old Jan 2, 2021 | 02:20 AM
OzAirtrek's Avatar
Sure try it and report back
Old Jan 2, 2021 | 06:08 AM
Ppwheelswa's Avatar
Ok!
mateshi
Apr 23, 2020 10:45 AM
Gormless
May 17, 2012 09:48 PM
4u2nvme
Dec 9, 2009 08:46 AM
Kierkegaard
Jun 2, 2009 05:57 PM
evo8dad
Nov 4, 2006 07:34 PM
