Tephra v7 engine light flashing
Old Jan 10, 2021 | 06:12 AM
JDL218's Avatar
Hi installed the tephra v7 now on boost getting the engine light flashing any1 know why?
jdm e7
cheers
Old Jan 10, 2021 | 06:23 AM
Biggiesacks's Avatar
It's flashing because you have engine knock. The settings are adjustable, but you should probably tune out / fix the knock.
Old Jan 10, 2021 | 06:26 AM
JDL218's Avatar
What could cause knock bro im still new and in a country that doea not speak english
iv put a few new parts on it could a bad ecm cause it cause i have a few elec issuses
Old Jan 10, 2021 | 06:56 AM
Hard to say in your particular case. Here in the states we have poor fuel and the stock ignition timing is too aggressive, so we get knock on the stock tune. Most likely you need to tune the car to eliminate the engine knock. You should also make sure there aren't any mechanical issues like boost leaks etc.
Old Jan 10, 2021 | 07:04 AM
JDL218's Avatar
Running 95 did do a hose change but it was not running that good when i got it compression is good is running a little rich as i can smell it
Old Jan 13, 2021 | 12:26 PM
240Z TwinTurbo's Avatar
Just in case...
https://www.evolutionm.net/forums/ec...-no-knock.html
Old Jan 13, 2021 | 08:24 PM
JDL218's Avatar
Mmm so knock or afr can i log afr with out a gauge and rear sensor. The guy i got it off said he had a fuel problem and he changed the pump. He did have it sitting for abit didnt really drive it for 6 yrs its only got 54000miles on it
JDL218
Jan 12, 2021 09:08 PM
rdtech
Oct 3, 2009 11:28 PM
localtoys73
Jul 25, 2009 06:20 PM
blkboyan1486
May 25, 2007 01:53 AM
Shingen
Mar 18, 2005 04:22 PM
