Guide: How to flash the Airtrek Turbo
Old Jul 21, 2021 | 02:15 AM
OzAirtrek's Avatar
Originally Posted by Mahwy1441
Yea battery was good i got a charger attached. I use the latest ecuflash i just downloaded since i just got the tactrix last week. Haven't tried evoscan or mitsulogger yet since i was just about to disable egr first.
Ok I would try just logging while the car is running next.. use evoscan or mitsulogger. If that works then you know there is no problem with the openport 2.0 ..
Based on your photos should be set correctly.. possibly your re flash connector is a bad connection?
The error is basically saying no response from car ECU is my understanding
Old Jul 26, 2021 | 09:59 PM
Mahwy1441's Avatar
Tried logging with mitsulogger and the status window says no device detected. Cant get through evoscan, are they still in business?
Old Jul 27, 2021 | 01:16 AM
OzAirtrek's Avatar
It sounds like your problem is the tactrix device (drivers?
Are you using a genuine device?
Complete reinstall?
Old Jul 27, 2021 | 01:21 AM
Mahwy1441's Avatar
Yeap bought directly from tactrix, i emailed them about the problem but no reply yet. Will try reinstall later, someone suggest to conect the tactrix and let the driver install before installing the openport?
Old Jul 28, 2021 | 01:00 AM
OzAirtrek's Avatar
Yes I would try that. You should be able to see it in your device manger once installed.
Old Jul 28, 2021 | 08:21 PM
scientist's Avatar
This has happened to me quite a few times with Airtreks.
Usually solved by:
1. Cleaning out and making sure there are no cold joints on the OBD connector as well as the Flash Connector
2. The Openport pins are not making proper contact, I resolved this by using a cheap OBD port extender on Ebay. Cars that gave trouble to connect or maintain a stable logging connection never gave issues after doing this
Old Aug 1, 2021 | 04:14 AM
Mahwy1441's Avatar
Usually solved by:
WIll do, just to be clear the flash connector is the green wire right?
Old Aug 8, 2021 | 02:29 AM
Mahwy1441's Avatar
Usually solved by:
Cleaned the obd pins and re did the reflash connector, works like charm now! Thanks!!!
Old Aug 8, 2021 | 03:47 AM
Mahwy1441's Avatar
EGR disable
Anyone here have disabled the egr on airtrek? Tried to disable from ecuflash but i still get cel and p0403 code. What else do i need to change?
P.s i removed all the egr solenoids since they're dead.
Old Aug 8, 2021 | 05:38 PM
nikush's Avatar
your trek is 2002 or 2004?
Old Aug 8, 2021 | 06:09 PM
Mahwy1441's Avatar
It's an '03 so i guess it's the same as '02?
Old Aug 8, 2021 | 06:18 PM
nikush's Avatar
can you post your rom?
Old Aug 8, 2021 | 10:03 PM
Mahwy1441's Avatar
sure.
File Type: zip
Old Aug 9, 2021 | 11:00 AM
nikush's Avatar
try this rom
File Type: rar
Old Aug 9, 2021 | 09:33 PM
Mahwy1441's Avatar
try this rom
Will do! Do i need to change anything or just flash it in?
