Tephra V7 SD Who can find the missing link....
Old Jun 30, 2021 | 02:44 PM
Evo8Emperor's Avatar
Sorry haven't really had a good chance to test your rom a little better other than flashing it to the car fast. Still had a cel though.
Once it cools down a bit tonight Im going to try and get out to it.
Old Jul 1, 2021 | 10:31 AM
Evo9_Dubai's Avatar
Give this a try. You wont have a CEL.
Old Jul 1, 2021 | 12:17 PM
Well you are some what on the right track. Flashed test2 to car and checked evoscan and i didnt see maf air temp scaled was reading what seemed to be ambient temps.
Still have the cel on though. Think that is due to the tuner pegging the MAT temp to 90.
I attached the log and heres the screen shot of codes.
Old Jul 1, 2021 | 12:48 PM
Evo9_Dubai's Avatar
Have you tried clearing the codes? I have them disabled so I am not sure why they are still showing up.
Also, without an actual IAT sensor, I do not think you can have the Air Temperature reading. If someone knows better please correct me.
Although the car should drive fine, I think. Let me know.
If it drives fine, no CEL, and MAF Air temp is reading correctly, you will just need to wire an actual GM IAT sensor into your UICP before the TB and run the wire to the ecu.. I will check which pin exactly.
Old Jul 1, 2021 | 01:05 PM
Thats the thing I do have a GM IAT sensor in the UICP. lol. So everything your seeing in the logs is coming from the GM IAT sensor.
For some odd reason the tuner is using the 94171715 older version 2d speed density rom. This rom is not reading the IAT sensor.
I gave him the car it was using 96530706 with no CEL and I was getting readings in evoscan.
Ive double check continuity back to pin 72 from IAT sensor and its fine.
Old Jul 1, 2021 | 01:07 PM
Ill go and try to clear the codes and try again.
Looking at the rom test2 you gave me the temp tables looked to be back to normal but the car is still idling high like it was still pegged at 90 degrees.
I honestly feel like the wires to my sensor might be wired in backwards.
Doesn't explain why car wont run off fuel temp sensor though. other than a bad fuel temp sensor.
Old Jul 1, 2021 | 01:46 PM
So cleared the codes and there was only one that remained. It was p0110 intake circuit malfunction.
Decided to try the FIC2150rev1 rom set to IAT as the input and i get the same code now p0110.
So I changed the input over to the fuel temp and no cel using the 96530706 rom. Car just runs like **** using it. Tried changing all the tables over to what the tuner inputed and I cant get it to run as smooth as he did still.
Here is the rom I just flashed to car. No CEL. Attached a log as well. Should be fuel temp as the input
File Type: bin
Old Jul 1, 2021 | 02:15 PM
Evo9_Dubai's Avatar
I know it's another long shot but try this. It might fix your high idle issue. Give it a try and let me know.
Old Jul 1, 2021 | 02:44 PM
So looking at the log with the fuel temp as input my injector pulse width doesn't move. I would think that i should see it move with me giving it throttle.
Old Jul 1, 2021 | 03:00 PM
Went out to try that test3 rom and at first it seemed like my idle stayed down but eventually it went back up.
I do however see my injector pulse width changing using these 9417 roms.
I feel like if we can figure out why i dont see a change with the 9653 roms then we could get the car running with no cel and see how it acts.
I attached the log for the test3 idling
Old Jul 2, 2021 | 04:14 AM
Does anyone have any idea what i would need to change in this xml bit for me to see it in a 9653 rom ?
<table name="Minimum IPW SHLL0" category="Global Fuel Settings" address="1502" type="1D" scaling="IPW16:SHLL0"/>
Old Jul 2, 2021 | 09:32 AM
Well I think Im onto something anyway. I had a suspicion that it was the pos harness the shop i had do the work to the car sourced. That and the fuel temp sensor is dead also.
For what ever reason car isn't throwing a code when its running off fuel temp sensor and all the parameters are right. Temperature was always reading way off know matter what ROM the car was running off. The tuners pegged one or mine.
So i ran a new set of jumper wires from ecu to GM IAT sensor and flashed car over quick to run off IAT and I got no CEL's and actually got ambient temperature readings in evoscan.
Going to go through it all and set up another ROM from scratch and see what happens.
Old Jul 2, 2021 | 10:41 AM
Well that definitely was the problem. Using a 9417 variant rom on 2d speed density with the GM IAT sensor as my input through the IAT pin 72.
Only thing i need to figure out is why i still get a -40 readings in evoscan for my MAT scaled.
pretty sure its probably my formula in evoscan. have to see if i can find the correct one unless anyone can point me in right direction..
redSLed
Jan 2, 2018 12:04 PM
black_out
Sep 15, 2015 12:26 PM
mace1890
Lancer Engine Management / Tuning Forums
Sep 20, 2011 08:05 PM
adcgn45
Aug 7, 2010 04:18 AM
nonschlont
Aug 6, 2010 01:01 PM
