Mechanical issue or setup/tune?
Old Mar 11, 2022 | 05:56 PM
black_out's Avatar
Im getting this car professionally tuned, but I haven't put many miles on it the past couple years so I wanted to get some dial in to work out any potential bugs and I'm trying to determine if this is a setup issue or a mechanical issue. Mods are-
ID1000s
walbro 255
fuel lab AFPR
omni 4 bar
Intercooler
Exhaust
Hks 264/272s
The car is a 98 eclipse with a 96531706 rom on an evo 8 ecu. Injectors are fresh, on 91 fuel. The front o2 sensor appears to be dead and I plan to lock it into open loop or use the wideband AFR patch to control closed loop until a new o2 sensor comes in. The issue I'm running into is the car goes dead lean when you get into boost. Since my o2 isn't cycling I planned to just dial injector scaling in with a quick WOT and locking the fuel table at a specific AFR to match it up. Using wideband AFR's I feel like my latencies and scaling are in a ball park to be half decent driveability wise to get into some low boost without pegging lean. You can see in the log that anywhere near 100 load (1:1 SDVE) it doesn't seem to be adding any fuel and just goes lean. I thought my AFPR diaphram was sticking but I can boost it with an air compressor and it runs fuel pressure up 1:1. I'd have to drop my scaling quite a bit to get WOT AFR's inline and I don't think scaling should be as far off as it would need to be. Current scaling is 975 and latencies are:
3.648
3.048
1.752
1.32
1.056
0.864
0.744
Am I just that far off on setup so far or does someone see something mechanical causing issues? I've had the car previously running fine on FIC1120 low-z but that was a few years ago. I just switched over to the ID's. Like I said I plan to have this professionally tuned but wanted to work out any bugs before hand. It starts/idles/cruises well enough, but I'd like to get things closer.
Old Mar 13, 2022 | 12:20 PM
Burning_scar's Avatar
Did you remove the injector resistor box?
Because for high-z injectors it needs to be done.
How to bypass the injector resistor box
Old Mar 14, 2022 | 09:25 AM
black_out's Avatar
Yes the box is bypassed. I run Hi-Z on 4 of my other 4g cars, I'm pretty familiar with setup on them.
Old Mar 20, 2022 | 11:47 AM
CDrinkH2O's Avatar
If you are on gasoline and running 43.5 psi base fuel pressure, your scaling setting is too lean for your ID 1000's. Try setting it closer to 812.
Quote:
Originally Posted by travman
PHP Code:
Code:
Code:
ID 1000s
Scaling: 812
latencies
4.69v = 5.328
7.03v = 3.144
9.38v = 1.992
11.72v = 1.368
14.06v = 1.008
16.41v = .792
18.68v = .624
Quote:
Originally Posted by Rawkus
PHP Code:
Code:
Code:
ID 1000s
Scaling 812
3.816
3.144
1.944
1.392
0.984
0.72
Old Mar 21, 2022 | 08:47 AM
black_out's Avatar
PHP Code:
Code:
Code:
ID 1000s
Scaling: 812
latencies
4.69v = 5.328
7.03v = 3.144
9.38v = 1.992
11.72v = 1.368
14.06v = 1.008
16.41v = .792
18.68v = .624
PHP Code:
Code:
Code:
ID 1000s
Scaling 812
3.816
3.144
1.944
1.392
0.984
0.72
Ill give these a shot and see how it fairs. I feel like the drop in scaling still isn't enough of a change to bring the WOT fueling back in line but I'll port them in tonight and see if it improves. Thanks!
Old Mar 28, 2022 | 09:13 AM
black_out's Avatar
Got a new o2 in so it would develop trims and ported in new settings. That got my idle and cruise both within +/- 1%, but still lean in boost. Swapped to a MAF ROM and its working fine for that now. Must be something in my SD setup not working, thanks for the settings!
tyler734
Jul 14, 2015 12:03 AM
Jeff_Jeske
Jun 18, 2011 06:49 PM
92LaserRs
Apr 15, 2011 12:56 PM
lp_ceo
Sep 29, 2010 07:22 PM
Fourdoor
Mar 15, 2010 09:34 AM
