ROM ID not found at 0x5002A
Old Apr 25, 2022 | 02:46 PM
GTR2014TE's Avatar
Hopefully this hasn't been asked a billion times, but I have the ROM I pulled off of an Evo I just bought that came with a few mods, and ran into a problem trying to get it's ROM ID. I opened the file in a hex editor and went to 5002A, and all the surrounding values are all FF. I did a quick google search and someone mentioned opening the rom using the Wizard option in ECUFlash, and selecting a different ROM as a template and I got: 52680122
That made me find another post on here that mentioned that it was a 52680022 ROM ID, but is a Tephra modded definition file. Thats cool and all, but I want to see what address the wizard is pulling this value in the file. So I searched for "52680122" in the hex editor and it pointed me to the address of 50141. Is this expected? Why is it there, and not located to the normal location (5002A)
One more question, if anyone can help me out. The car has a full exhaust, stock intake, and I have no clue if what injectors/fuel pump it has at the moment (hoping stock for stock.) Would it be better to just buy a new ROM from tephra, and start over, or try to figure out how to get into my current ROM and start from there? I obviously don't mind buying the new ROM, but I'm just curious if I can link my current ROM's modifications to the new one that I will purchase.
Thanks!
Old May 13, 2022 | 02:44 AM
crimson red's Avatar
Save the rom as '.bin' or '.hex' (NOT .srf) then open the rom you saved by a hex editor. Check the values around 0x5002a. What values do you see?
Removing one of your injectors and confirm it by your own eyes is the simplest way. Removing and reinstalling the injectors is very easy.
Size of the fuel pump does not affect ecuflash tables. If you drive a car with your usage and the pump capacity is insufficient, change the pump with a larger one.
iienigmaii
Jan 27, 2024 02:53 PM
GTR2014TE
Apr 25, 2022 02:45 PM
etc91
Mar 17, 2020 01:49 AM
MisterrTurtle
Nov 9, 2019 08:28 PM
tsidrift1
Oct 25, 2011 10:06 AM
