Ecuflash only loads base 9 rom?
Old Oct 24, 2011 | 05:32 PM
tsidrift1's Avatar
So I got some new injectors hooked up. I want to start dialing them in. I tried to read my rom from my ecu. The very first time I tried to get it, I got the error mesage that it was an unrecognized rom. I shut it all down, reconnected it, now I get basically a bse evo 9 rom. I had tephra v7 when I was tuned 4 weeks ago from Devin at Boostin. Shouldnt I see the tephra options? I have the user level at the highest to see if they would come up then, but still nothing?
Why cant I get it to read my ACTUAL tuned rom??
I searched, but only found info about not being able to read a rom. period. Mine reads one, but its like the wrong one, maybe?
Thanks,
Anthony
Old Oct 24, 2011 | 06:11 PM
Raptord's Avatar
Do you have the tephra mod xml?
Old Oct 24, 2011 | 06:24 PM
Evoardo IX's Avatar
This. Make sure you have the V7 xml in your ecuflash roms folder.
Old Oct 24, 2011 | 06:25 PM
GGevo921's Avatar
^+1 and you also will need to put evo 7 base map read template in your romedata so you can read the rom from your 8
Old Oct 24, 2011 | 06:31 PM
tsidrift1's Avatar
I do not. I thought I had found it earlier. I downloaded it, and then moved it into the ecuflash folder. I tried opening it and it said it wasnt found. i am tryin to understand all this stuff, but I am a former dsm guy. Link was very straight forward lol.
I am hoping Devin will just email me the rom for my car he tuned. A part of me wants to get it all going myself though.
Got a link to the correct rom? Now, once I get this rom into the ecu, will ecuflash then recognize it and all my settings will come up?
Old Oct 24, 2011 | 06:34 PM
Evoardo IX's Avatar
even if your tuner sends you your rom, you won't be able to open it/ see it/ tweak it/ unless you put said xml in the right folder: program files/ openecu/ ecuflash/ rommetadata/ mitsubishi/ evo.
Old Oct 24, 2011 | 06:40 PM
tsidrift1's Avatar
Hmm, ok, I will have to give this a try in the morning. So once I load the v7 xml in the evo folder, then read from ecu again, it should pop up then?
Old Oct 25, 2011 | 10:06 AM
tsidrift1's Avatar
I must have put the tephra xml in the right folder. I got the map from my tuner this morning and sent it to the ecu. I can see all the tephra options.
Thanks guys,
Anthony
Decil
Apr 21, 2017 12:28 AM
br3akrboi
Dec 6, 2015 11:40 AM
Sheasta
Nov 2, 2015 12:29 PM
steven121
Feb 9, 2013 08:16 PM
03whitegsr
Oct 17, 2009 10:20 PM
