TephraMod V7 - How to enable EGR? Factory Lean sppol setting?
Old Apr 24, 2025 | 07:39 PM
Jhero23's Avatar
TephraMod V7 - How to enable EGR? Factory Lean spool setting?
What setting do I need to change to enable EGR?
Is the lean spool supposed to be disable from factory? If not, what setting does it need to be start/stop RPM.
USDM Evo IX
Option 1 88590715 (v7)
Option 2 - Thanks to recompile 88590715 (v7 + Mods)
  • Setup for JDM MAP and PSI based boost control (mrfred)
  • WGDC Correction Interval set to 1 (Stock = 10)
  • Max Total Upward WGDC Correction @ 100% TPS set to 0 (Stock = 10)
  • EGR System Disabled (mrfred)
  • Max Timing Retard set to -20 degrees (tephra)
  • FAA bit.10 disabled ("weird unknown" timing pull at cruise)
  • FAA bit.09 disabled (cat-warmup ignition retard)
  • FBA bit.00 disabled (lean spool)
  • FCA bit.09 disabled (EGR Test)
  • OBD Inspection set to Pass all tests (acamus)
  • Rear O2 Heater patch applied (mrfred)
  • Fuel Cut Load Limit x2 and set to 300 (mrfred)
tephra
Apr 22, 2026 11:03 AM
dylankellner
Jan 6, 2025 06:05 AM
stunt2
Jul 14, 2020 08:37 PM
tephra
Aug 19, 2016 10:07 AM
C6C6CH3vo
Jun 24, 2007 05:38 AM
