Ecuflash using mapsensor w/o piggyback possible?
Once the entire rom is reverse engineered, Its certainly possible for someone to do it.. Will it happen? Well, nobody can say. I do have to keep reminding people that Speed Density is just not all that great.. having a MAF makes for much better drivability.. At this point your probably better off buying something that can offer the feature to convert it to a MAF Karmann signal..
So for example just purchasing a maft pro to convert to map and leaving settings at zero and just tuning in ecu flash.
Target AFR
Target AFR For alky
Fuel Trim for alky
Can make fuel adjustments without a laptop
etc...
ecuflash+maftpro is an awesome combo
Why is that, does converting over to map make the car run leaner?
Ryan Evans
Lancer Engine Management / Tuning Forums
Jun 29, 2016 11:11 AM
LePaGe20
10
Nov 7, 2008 07:55 AM
BLiu
19
Jul 27, 2004 11:55 AM
