problem connecting
problem connecting
I can't get my EVO to connect. I have a IX, but I was under the impression that I could read my ECU, just not change it.
Here is what it says:
[08:11:49.953] Version 1.27.658
[08:11:49.953] 9 memory models read.
[08:11:50.343] 66 ROM metadata models read.
[08:11:50.343] checksum module "subarudbw" loaded.
[08:11:50.343] flashing tool "wrx02" loaded.
[08:11:50.343] flashing tool "wrx04" loaded.
[08:11:50.343] flashing tool "sti04" loaded.
[08:11:50.343] flashing tool "sti05" loaded.
[08:11:50.343] flashing tool "evo" loaded.
[08:12:07.296] This vehicle interface does not support needed features.
[08:12:07.296] unable to connect to vehicle interface.
[08:12:46.843] This vehicle interface does not support needed features.
[08:12:46.843] unable to connect to vehicle interface.
[08:12:58.859] This vehicle interface does not support needed features.
[08:12:58.859] unable to connect to vehicle interface.
Girlie
Girlie
It says this vehicle interface does not support needed features, which is not what I got on my VIII when I was unable to connect due to a port issue, so maybe it's just not compatible.
However, just to be sure, check your Options>Port to make sure it's set to use the 1.3 OpenPort.
Make sure you plug your cable in before you start the EcuFlash software or else it wont recognize it. Try resetting also, especially if you just installed the drivers.
Originally Posted by Girlie
The only thing that comes up under Options-Port is COM3
MonacoGP
Apr 8, 2011 02:06 PM
jmcmill3
Nov 22, 2009 12:13 PM
