log boost with JDM MAP sensor (updated instructions)
Old Oct 20, 2012 | 12:50 PM
  #811
Nimpoc's Avatar
Typo corrections
1. Thanks to all dev's for doing this stuff!
2. There is a typo in the instructions for two of the ROM sets. "EGR MAP Check #" should likely read "EGR MAP Offset #". See red highlights below.
3. It's not totally clear if one is on 008 ROM vs. 007 ROM which .xlm should be patched. I did both...
4. I initially had trouble getting the .xml updates to show up in EcuFlash. I tried pasting into the end per the instructions, and when that didn't work, into the beginning just after "<include>evo7base</include>". I updated the following .xml's just in case some path was screwed up:
C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ 96420007.xml
C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ 96420008.xml
C:\Users\mike\Documents\EvoScan v2.9\ROMS\96420007.xml (this is where I keep my ROM files)
C:\Users\mike\Documents\EvoScan v2.9\ROMS\96420008.xml
Dev mode + invalid tables + tables beyond = all on.
[12:16:02.145] EcuFlash Version 1.43.3252
[12:16:02.145] OS Version Windows 7
[12:16:02.145] Qt Version 4.6.2
Nothing. Started writing this then suddenly started working... My question is, what's the best practices for file locations so both apps consistently hit the same files?
Cheers,
MK
Originally Posted by mrfred
Updates
ROM Mods for 2004 USDM Evo 8 ROMs 96420007, 96420008
First is to add some definitions to your ECUFlash ROM XML definition file found in:
C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Open the 96420007.xml file with the text/XML editor of your choice. Scroll down to the bottom of the file. Add the following lines just before the </rom> tag (copy everything *between* the ----):
<table name="MAP Test 1: Mid VE Max Voltage" category="MAPSensor" address="2048" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 1: Mid VE Min Voltage" category="MAPSensor" address="2046" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 2: Low VE Max Voltage" category="MAPSensor" address="204C" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 3: High VE Min Voltage" category="MAPSensor" address="2050" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 4: Max Minus Min" category="MAPSensor" address="2054" type="1D" level="1" scaling="Volts16"/>
<table name="EGR MAP Check 1" category="MAPSensor" address="4EEC" type="2D" level="1" scaling="uint8">
<table name="RPM" address="6D74" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="EGR MAP Check 2" category="MAPSensor" address="4EFC" type="2D" level="1" scaling="uint8">
</table>
<table name="MAP Scaling for Baro" category="MAPSensor" address="12059" type="1D" level="1" scaling="uint8"/>
<table name="EGR Pressure Diff" category="MAPSensor" address="1F62" type="1D" level="1" scaling="Volts16"/>
<table name="ECU Periphery2" category="ECUPeriphery" address="fca" type="1D" level="1" scaling="Hex16"/>
After modifying and saving the ROM xml file, launch ECUFlash, open your ROM, and find the new entries. Note that they have their own category. It may be necessary to set ECUFlash to "Developer" mode in the ECUFlash options (and relaunch ECUFlash) to be able to see the tables. Here is what needs to be changed in ECUFlash:
MAP Test 1: Mid VE High Voltage Test -- Change from 4.61 volts to 4.80 volts.
MAP Test 1: Mid VE Low Voltage Test -- Change from 0.10 volts to 0.06 volts.
MAP Test 3: High VE Voltage Test -- Change from 1.80 volts to 0.51 volts.
MAP Test 4: Max Minus Min -- Change from 1.80 volts to 0.51 volts.
"EGR MAP Offset #1" should read:
750 97
1000 86
1250 75
1500 67
1750 52
2000 56
2500 65
3000 63
3500 60
And "EGR MAP Offset #2" should read:
750 97
1000 86
1250 84
1500 67
1750 52
2000 56
2500 65
3000 63
3500 60
Change *both* tables to:
750 84
1000 84
1250 73
1500 65
1750 60
2000 55
2500 48
3000 43
3500 23
Change the "MAP Scaling for Baro" from 50 to 150.
Change the "EGR Pressure Diff" from 0.12 to 0.04.
If you wish to disable the EGR test, change the ECU Periphery2 parameter from EFDF to EDDF. (Type 0xEDDF.)
Save the ROM file, and flash your ECU with it. That's it for the ROM mods. Now skip down to the end of this post to see instructions for setting up EvoScan/Mitsulogger to log boost.
ROM Mods for 2004 USDM Evo 8 ROMs 94170014, 94170015
Open the 94170014.xml or 94170015.xml file with the text/XML editor of your choice. Scroll down to the bottom of the file. Add the following lines just before the </rom> tag (copy everything *between* the ----):
<table name="EGR MAP Check 1" category="MAPSensor" address="4DE4" type="2D" level="1" scaling="uint8">
<table name="RPM" address="6C0A" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="EGR MAP Check 2" category="MAPSensor" address="4DF4" type="2D" level="1" scaling="uint8">
</table>
MAP Test 3: High VE Voltage Test -- Change from 1.8 volts to 0.5 volts.
750 97
1000 86
1250 75
1500 67
1750 52
2000 56
2500 65
3000 63
3500 60
750 97
1000 86
1250 84
1500 67
1750 52
2000 56
2500 65
3000 63
3500 60
750 84
1000 84
1250 73
1500 65
1750 60
2000 55
2500 48
3000 43
3500 23
Old Oct 20, 2012 | 01:14 PM
  #812
Nimpoc's Avatar
FWIW, I unwound all the changes except for:
And it's still working. Go figure.
Not that it should matter, but I'm running a fully updated (and legal) copy of Win7.1x64 atop Parallels 7 on a 10.8.2 MacBook Pro 6,2. Runs everything fine, including Solidworks and stupid in-house dirty code from work.
Old Nov 3, 2012 | 07:31 AM
  #813
BoostBaby's Avatar
Originally Posted by BoostBaby
I've been searching around for a while now and can't seem to find the map sensor definition tables for my JDM IX MR...80920002 (inherits 88570008)
I just installed an Omni 4 bar and am unable to rescale it because the tables aren't defined. Thanks for the help in advance guys.
bumping for some help.
Old Nov 30, 2012 | 11:11 PM
  #814
limaynard's Avatar
Originally Posted by ch53avitech
Yeah, so my issue is still unresolved. $20 to whoever can help me fix it.
Hi, did you ever resolve this? I have exactly the same issue with my JDM 2002 Airtrek Turbo. At stationery idle the JDM 3 bar MAP Sensot is reading 14.7 psi...
Old Jan 1, 2013 | 07:25 PM
  #815
CRONZ305's Avatar
I'm still having issues with setting the values to the exact ones in the how to. It won't let me set the correct increment.
Old Apr 3, 2013 | 11:05 AM
  #816
BoostBaby's Avatar
Gotta bump this again...anyone got a JDM IX and installed an omni 4 bar map?
I'm looking for the map sensor definitions so I can get to rescale it.
Mrfred's thread only caters to the omni map sensor being installed on a USDM car.
https://www.evolutionm.net/forums/ec...evo-8-9-a.html
Please help.
Old Apr 15, 2013 | 03:36 AM
  #817
Jesussaves1's Avatar
how hard is this install of the 3 bar map sensor on a 2005 evo 8? is it just plug in and re flash the ecu?
Old Apr 15, 2013 | 05:48 AM
  #818
evo8426's Avatar
Super easy install. It might take you a full minute to swap out.
Old Apr 15, 2013 | 10:10 PM
  #819
CDrinkH2O's Avatar
Yep I can confirm that it is really simple. I flashed 96530706 and log JDMMAP in EvoScan at MUT request ID 38 using 0.19347*x-14.7 - piece of cake!
Old Apr 19, 2013 | 10:12 PM
  #820
kyoo's Avatar
What do you guys torque the map sensor down to? hand tight?
Old Apr 19, 2013 | 11:51 PM
  #821
RUDEBOY77's Avatar
Tight enough not to leak but not too tight to break the screws. dont kill it, use finesse
Old Apr 20, 2013 | 08:23 AM
  #822
kyoo's Avatar
lol. just hand tight then?
Old Apr 20, 2013 | 10:50 AM
  #823
RUDEBOY77's Avatar
Service manual states 44 +/-9in lbs, so snug.
Old Apr 20, 2013 | 07:36 PM
  #824
ApacheToYaDome's Avatar
I feel really dumb right now for this formula 0.19347*x-11.8 what would it be? I live at 6000ft elevation
Old Apr 20, 2013 | 07:49 PM
  #825
I think I'm over thinking this
In the following instructions, please use your formula in place of the words FORMULA HERE.
For EvoScan 0.99+, the MAP logging definition in the Data.xml file should be changed to:
<DataListItem DataLog="Y" Color="" Display="JDM MAP" LogReference="JDMMAP" RequestID="38" Eval="FORMULA HERE" Unit="psig" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="35" ChartMin="-15" ChartMax="35" ScalingFactor="1" Notes=""/>
So where it says "FORMULA HERE" I just enter 0.19347*x-11.8?
