how-to: ECU-based direct boost control
Old Mar 29, 2014 | 03:53 PM
  #1066
Werdna06's Avatar
i don't think i do because i checked the numbers to ports like 3 times to make sure it was right. it's brand new too. don't they do a check before they ship them? that's why they have the inspector sign a card that goes in the box. do i need restrictor pills?
Old Mar 29, 2014 | 04:32 PM
  #1067
RazorLab's Avatar
Sounds like either of the two things I mentioned. If you are logging WGDC like you are, you should be above WG pressure and see changes with adding WGDC.
A good amount of people hook up the ports incorrectly and that will get you WG pressure no matter what you do in the ECU. What ports do you have going where?
Old Mar 29, 2014 | 04:37 PM
  #1068
ronaldo9's Avatar
Definitely don't need any restrictor pills. I hope this helps you, but I'd check and make sure you hooked everything up correctly.
Old Mar 29, 2014 | 04:49 PM
  #1069
jeffbeagley's Avatar
Originally Posted by razorlab
Sounds like you have the 3 port installed incorrectly or a bad 3 port.
This diagram is for a different setup, but it should help you out.
Old Mar 29, 2014 | 05:48 PM
  #1070
Werdna06's Avatar
thanks for info guys i'll check it again tomorrow it's raining right now :/ i'll put an update after i do.
Old Mar 29, 2014 | 07:06 PM
  #1071
killerpenguin21's Avatar
60% with higher rpms and gears tapering to 57%. i don't have a boost leak tester right now but before i installed the ebcs i had a hallman mbc with no issues.
my car is stock 9 turbo/map o2 housing/turbo back/ic, currently running mid 60's WGDC in the midrange and running up to mid 80's to 7k to produce 24psi tapering to 20ish...have had to drop my wgdc's 5-8% since o2 housing install.
Old Mar 30, 2014 | 12:48 PM
  #1072
Werdna06's Avatar
and more rain, so no progress on resolving boost issues. but i did accomplish one goal for the day, i'm finishing up an egr delete on a 91 300zx TT. biggest pita ever. time to piece the fair lady back together.
Old Apr 11, 2014 | 06:04 PM
  #1073
Werdna06's Avatar
well i finally got around to checking the install, and it's fine 1 to intake, 2 to wastegate and 3 to turbo. ???? it has to be something with my ecu then, i'm running tephramod v7 and i've read the how to for boost control but it's not doing it, what else should i be looking at?
Old Apr 11, 2014 | 06:45 PM
  #1074
ReaperX's Avatar
If you'd like, send me the rom with the changes you have made and I'll look it over. Still got my email address?
Old Aug 4, 2015 | 10:09 AM
  #1075
03Ev0luti0n's Avatar
Kind of lost on this...
Running Tephra V7 and ECU controlled boost on a BW 7670 w/ Dual EWGs.
Was running the EBCS as a 2 port system (top port of EWG was vent to atmosphere) car was extremely laggy but made boost and held great at roughly 40% WGDC. It just wasn't very consistent. Target would vary between 18-25 lbs.
I changed the WG plumbing to a 3 port system as I was told it may help with lag and more consistent boost curve. I zeroed BEC table and set WGDC to 5%. No it's boosting to 30 psi consistently at 5% WGDC?
When I was running a stock turbo I had to drop my boost adder to 10.6 to keep the stock turbo from over boosting at just 50% WGDC despite living in Atlanta, GA and no where near that high of an elevation. Do I need to just keep dropping the Boost Adder? My target boost is set at 24.9psi
Old Aug 4, 2015 | 12:25 PM
  #1076
Solved my own problem.. I had run the EBCS backwards. Followed the picture diagram above from JeffBeagley and its responding great. even running the correct "atmospheric pressure values per evelation as discussed by mrfred...
Old Aug 10, 2015 | 09:16 AM
  #1077
sevic69's Avatar
Hello.
I can't see the code that we have to add to our xml files. My ROM is 94170015, could someone please help me? I have tried on many computers and phones, with the same result. I need the tables for Ecuflash, also the scalings, and also the code that we have to add to Evoscan. Thank you very much.
Old Aug 10, 2015 | 05:29 PM
  #1078
sevic69's Avatar
Found a solution. By quoting the message where I couldn't see the code, I can see the original raw text. Still, i don't know why I am having this issue. It is with any thread that contains code.
Sebas
Old Aug 11, 2015 | 09:13 AM
  #1079
Raptord's Avatar
It's happening to me and others as well, don't know what's going on.
Old Aug 16, 2015 | 08:43 AM
  #1080
ixbreaker's Avatar
^^ yea. what's the deal with the missing xml code for everything. I thought it was just certain posts. But it looks like all of the code is being deleted? Is it just mfred's work or everyone else as well?
