how-to: Log AFR from the LC-1 w/o a serial cable
#183
I am having the same problem. But, I did have it working for a few minutes. Once I shut off the car and turned it back on, it would not work again.....it reads 20 AFR constantly (as if the analog wire is putting out a constant 5 volts)
#184
The formula i originally entered was wrong so after i fixed that it read fine. But it still reads a little different compared to my gauge.
#185
#186
Damn, I'm having a noob moment here.. which is mut12? is that mut1x (and then over to column 2? the orig. value there is 0x88DD). I changed that and get a steady... 7.35. This is with the v7t5 evo8 tephra rom.
#195
alright guys im having trouble with the ecuflash part. what is mut address. im using 94170015
<table name="Rear O2 (ADC 0A) RAM variable" category="Rear_02" address="?????" type="1D" level="1" scaling="Hex16"/>
PLEAE help . i have the pin installed and tephra's o2 simulator on. i tired to log it but its at a steady 13.xxAFR through the ecu.
