downloaded the AYC/ACD ROM
Old Oct 13, 2008 | 12:37 AM
  #61
fbikawi's Avatar
Originally Posted by oldevodude
Garage HRS has already cracked and allowed modifications to the ACD
Too bad their system probably has AYC integrated as well. In reading it looks like one mode might lock the center diff. full time as they speak of increased tire wear...
I've brought this system up in several threads. It would be neat if someone knew more about it.
GEMS sells a modified acd/Ayc unit to Rally peeps that is programmable as well. It looked pretty pricey though.
garagehrs-dot-com is source for pic..
can anybody tell me how to order the ACD flash kit from Garage HRS Japan.
i sent an email but it seems they dont communicate in English. Do they have an agent or dealer in US?
Old Nov 4, 2008 | 10:47 AM
  #62
fil78's Avatar
look here
http://www.evasivemotorsports.com/Me...Code=CYBER_ECU
Old Nov 13, 2008 | 07:14 PM
  #63
oldevodude's Avatar
If you do end up finally getting this report back to us and let us know how it goes please.
Thanks
Old Jan 18, 2009 | 10:36 PM
  #64
fixem2's Avatar
SO with all this progress, can anyone update? Be great to have the ability to play with this for the upcoming race season.
Old Jan 20, 2009 | 10:45 AM
  #65
SPAWN's Avatar
Check this out !!!!
http://www.lancerregister.com/showthread.php?t=240332
think of buying it!!
Old Feb 12, 2009 | 02:57 PM
  #66
SoCalRedLine's Avatar
Any updates on How to flash the acd controller?
Dynamic autosports is now offering flashes, and I'd like to learn more
Old Mar 19, 2009 | 01:46 PM
  #67
rolly1818's Avatar
Registered User
bump!
Old Mar 19, 2009 | 09:19 PM
  #68
JohnBradley's Avatar
So it looks like the flash unit interfaces with the ACD ECU out of the car and flashes it with the serial cable?
Old Mar 20, 2009 | 02:04 PM
  #69
lan_evo_mr9's Avatar
That would be awesome if ecuflash had that capability. I wonder what program they're using to do it.
Old Mar 21, 2009 | 12:18 AM
  #70
Fast_Freddie's Avatar
Veteran: Navy
Look at the Garage HRS unit... The little black box on the top left is the interface device. The A/C adapter plugs into that, as well as the serial cable. The wire loom will then plug into the interface device to power/communicate with the ACD unit... then run the software...Looks pretty straight forward as far as the idea but as usual I have no idea about programming sortware....
Old Mar 21, 2009 | 03:14 PM
  #71
sba's Avatar
sba
I'm able to read the AYC Ecu. I readed a stock one and a Ralliart. I also can write then how i wish.
I'm working in the chiptuning company and i have a tool that makes also this ecus.
Unfortunately, i'm in Romania which pretty far.
But if somebody really wants, i can write anything that he wants inside the AYC ecu. I will also post a bin file of a stock ecu for the dissansembly guys.
NOW
Ralliart has 5 types of AYC ecus. I put my hands only on K2 model which is for gravel rallies.
Did anybody used something different??? I'm curious which is the best AYC variant for road?
If somebody has any ideas, i'm opened to anything
Old Mar 21, 2009 | 03:20 PM
  #72
joyce1bro's Avatar
NOW
ok are we talkin AYC or ACD?? i have never heard of other versions of AYC
usually they just go from AYC to LSD.... if however you can manipulate the AYC ROM i would love to know more.... 50/50 split on both rear wheels 100 percent of the time or on WOT would be grreat....
Old Mar 21, 2009 | 03:44 PM
  #73
sba's Avatar
sba
There is only one ecu for both.
Old Mar 21, 2009 | 10:27 PM
  #74
fixem2's Avatar
If they are the same ECU, when you pull the AYC are you also pulling the ACD code? Is this for the Evo 8,9 or X?
Please post the bin file.
Old Mar 22, 2009 | 12:46 AM
  #75
fostytou's Avatar
EvoM Community Team
I can definitely host the file for you if you need... plenty of space and bandwidth. PM me for an email addy.
Also, if you wouldn't mind sharing some info with tephra, JCSBanks, MrFred or anyone else on how to read/write/interpret that would be great!
