accurate 90550001 xml's
just looking for some accurate 90550001 rom xml's. after i upgraded to ecuflash 1.41 half of my definitions disappeared. so i went back through and set everything back up but now some of the maps and such look a bit off.
well it still didn't work for me but i found out why. somewhere along the line i had switched over to 96530006 and in the process i ended up with a newer version of the evo7base xml. a lot of the tables that were in the new xml had changed, mostly just names. so after adding the tables that i was looking for and fixing a few other little things i have managed to put together a pretty complete evo7base xml. i tried to keep all the correct addresses from the 9055 xml cossie sent me. also, i have included my 7base in the zip file as well as a txt with a couple of tables that are giving me some trouble. some of them aren't that important, to me at least, but they were originally there so i am sure someone has use for them. i did try opening a couple of other roms with my new 7base and they looked like they were fine but i wasn't totally sure if they were complete. if someone wants to take a look and tell me what they think. once it is squared away i am going to submit it to jcbanks for the ecuflash update.
thanks
mike
thanks
mike
I hate to bring this thread back from the dead but I'm trying to find a good xml for 90550001. Every thread I come across has broken links or unusable downloads. Just need a good 90550001xml so I can view a buddy's rom. Can anyone help?
There is one at http://ecurom.googlecode.com/svn/tru...o/90550001.xml
You also need evo7base.xml which is at http://ecurom.googlecode.com/svn/tru...o/evo7base.xml
