Speed Sensor OBDII (P0500 code) fault
Old Jan 19, 2010 | 04:34 AM
veszett's Avatar
Has anyone had or seen a P0500 Speed Sensor code pop up when checking for OBDII faults???
It seems that ABS, Speedo, Rev's work and I don't have a CEL.
I've reset the ECU numerous times but it keeps re-appearing. I've even spoken to Mitsubishi but they haven't heard of the Speed sensor failing before.
The only reason I checked for codes was after i flashed Tephra v7 with the gear based boost, my boost was fluctuating up and down and didnt know where to go. This boost issue does not happen with any other rom (97250001 & 96260007) with same settings but the OBDII fault code is still present. Maybe the P0500 fault is the reason for boost fluctuation in v7?
Anybody have any ANY ideas??
Old Jan 19, 2010 | 06:19 AM
hediki12's Avatar
happened to me when i did the evo 8ecu swap into my 2g the 1st time and i accidentally pulled the wire out the ecu when i was re-pinning.. double check that 1st.. then make sure the the sensor is clip is on properly on the tranny. other than that im stumped... but ive herd of them goin bad in dsms.. so .hey... good luck!
Old Jan 19, 2010 | 08:15 AM
veszett's Avatar
thanks mate thats a good point, i'll have a look at the ecu wires tomorrow...we checked the clip with the mitsu guys at the dealership and that was in place. fingers crossed!!
Old Jan 22, 2010 | 03:24 PM
mikespike2's Avatar
Did you get this figured out by chance? Just had it come up today.
Old Jan 22, 2010 | 10:00 PM
veszett's Avatar
ok, i checked the ecu and pins and...looks like the previous owner had some mods done. anybody wanna buy a HKS Speed Limit Defencer?? works perfectly, LOL!!!
Old Jan 22, 2010 | 10:05 PM
veszett's Avatar
mate, i think my problem may be different to yours but here is a diagram i found which may help if it is your wiring. if you need the full electrical manual pm me. good luck!
Attached Thumbnails Speed Sensor OBDII (P0500 code) fault-ecu-diagram-speed-sensor.jpg
Old Jan 23, 2010 | 05:54 AM
hediki12's Avatar
check connections to the ecu and speed sensor....
Old Jan 23, 2010 | 05:55 AM
hediki12's Avatar
glas i helped in some way!.
Old Jan 23, 2010 | 05:02 PM
burnzy's Avatar
the speed limit defencer would be sitting in between the cut speed wire thats all, just cut out the box and join the 2 wires. Theres only 4 there, 2 are going to power ground, the other 2 are joining the speed sensor wires.
Yellow - Speed sensor wire to ECU
White - Speed Sensor wire to loom
Black - Earth
Red - 12V ignition feed
no need to pay an electrician mate if you have some common sense.
Old Jan 23, 2010 | 07:32 PM
veszett's Avatar
Black - Earth
yeah i know, i had a look at the connections last night after i downloaded the install instructions and it took me 5mins to unplug the cursed device (its personal, hehe) and reconnect the original wires. Quick test drive/log and SPEED is now logging!!
Now i can flash v7 over and hopefully this would have solved my boost issue with the gear based setup... from a slightly different angle, damn these HKS SLD's are pricey!
Old Jan 24, 2010 | 07:14 PM
veszett's Avatar
have you had any luck with yours? do you have any other symptoms??
Jaws567
24
Jun 1, 2021 08:25 AM
Rico8638
Jul 13, 2019 10:29 PM
bruce988jl
May 19, 2017 02:58 PM
psyc0de
Mitsubishi TC-SST Discussion
Apr 27, 2017 01:56 PM
bsh
Nov 23, 2012 01:11 PM
