Tuning and logging issues, Please help. Nothing Works!
I had a problem with my usb to serial adapters, sometimes it would work with evoscan and then sometime it would work for logworks. I just gave in a got a laptop with a serial port, paid 120 for and cleared all the problems i was having. It might be the usb-serial adapter give another one a try and see what happens
yes this is great advice.. unchecking log to screen speeds up data rate by at least 2x quicker. the only problem is, evoscan can be buggy with widebands and you have to start it and turn it off to get it to kick on every now and then and if you dont log to screen you have no way of knowing if its logging the wideband or not.. i suppose you could throw up a custom widget just for the AFR tho.
even with correct eval etc, evoscan 2.8, brand new sensor etc I can't get the stupid thing to act right. And it's not the typical signs of a dead brain.
I think it's working now, but I haven't had a chance to go out and test it.
Thank you to everyone who took time to give me some advice! It's working great! I just got done installing my Innovate db gauge and EvoScan is reading dead on with the gauge. Here are some Virtual Dyno Graphs.
Blue is the first run, Red is second, and Green is a log from Jan 2010.
It's spiking 23psi, 0 counts of knock, and pig rich hitting 10.9 at 5000rpm and continuing to 10.2 at rev limit 7500rpm.
I need to get an Omni 4bar so I can start logging boost. I hit 270 and tapers to 180-200 by redline.
Also, switched to TephraV7-94170715! Only issue I had was hitting fuel cut because I forgot to change to upper limits! Works great and lots more resolution for tuning. Thanks again to all those who contributed!
xPRimNT
239
Jun 2, 2016 10:40 PM
anthony penn313
Lancer Engine Management / Tuning Forums
10
May 17, 2014 02:58 AM
