Tephra v7 alt maps
Tephra v7 alt maps
Does anyone know how to add more options to tephra's alt maps? Instead of just another set of boost, fuel and timing tables I would also like to add the immobilizer code as well to the second set of maps.
ecuflash
Evos are getting stolen in cali a lot lately. I had this idea that if people weren't using the alt maps for a dual tune they could use it to prevent someone from being able to start the car. For example, a map switch could be in the car somewhere. One map has your regular tune with the immobilizer code. The other map has the immobilizer code missing meaning the car won't start. So when you leave your car at a shopping mall you just hit the switch then the car won't start for someone trying to hot wire it. When you return you just hit the switch again and drive home.
