RequestID="CALC" not working for EvoScan v2.9.0023?
Just you, I reckon!
RAX Fast Logging is totally built on CALC processing, from front to back. I mean, "Boost" is a CALC item that uses "[MAP]-[Baro]". MAP and Baro are themselves CALC items, with bitwise operations used to extract the packaged RAX data.
If you can attach your raw XML config file, I'd be happy to take a look...
Rich
Rich
Just you, I reckon!
Rich
Rich
Here's a pared down version of an xml where the CALC does not work for me. This is with a 1.3 cable on an Evo 9.
Code:
<?xml version="1.0"?> <EvoScanDataLogger> <vehicle name="Mitsubishi MUTII MMC 1G DSM OBDI - EFI"> <ecu name="EFI mrfred broken CALC"> <Mode2 name="Mode2" type="Data List Items"> <DataListItem DataLog="N" Color="" Display="MIVEC Intake" LogReference="MIVEC" RequestID="77" RequestID2="78" Eval="72-0.6*x/32" Unit="crank deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-1.2" GaugeMax="28.8" ChartMin="-1.2" ChartMax="28.2" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="MIVEC CALC" LogReference="MIVECcalc" RequestID="CALC" Eval="239*[MIVEC]" Unit="whatever" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-1.2" GaugeMax="28.8" ChartMin="-1.2" ChartMax="28.2" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> </Mode2> </ecu> </vehicle> </EvoScanDataLogger>
Odd. Compare to RAX Fast Logging style...
DataLog="N" to DataLog="Y" ?
Don't know...
Rich
Code:
<DataListItem DataLog="Y" Priority="2" PriorityOffset="0" Color="" Display="------RAX_D_Dat------" LogReference="RAX_D_Dat" LogHide="True" RequestID="238051b4" Eval="x" Unit="binary" MetricEval="" MetricUnit="" ResponseBytes="4" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Visible="False" /> <DataListItem DataLog="Y" Priority="1" Color="#80ffc0" Display="Baro" LogReference="Baro" RequestID="CALC" Eval="([RAX_D_Dat]BITS(23,7) + 90 ) * 0.07251887" Unit="PSI" MetricEval="([RAX_D_Dat]BITS(23,7) + 90 ) * 0.5" MetricUnit="kPa" ResponseBytes="4" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Visible="False" LogHide="false" /> <DataListItem DataLog="Y" Priority="1" Color="#c04000" Display="MAP" LogReference="MAP" RequestID="CALC" Eval="[RAX_D_Dat]BITS(32,9)*0.0964869" Unit="PSIG" MetricEval="[RAX_D_Dat]BITS(32,9)*0.6652542" MetricUnit="kPa" ResponseBytes="4" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Visible="False" LogHide="false" /> <DataListItem DataLog="Y" Priority="1" Color="#ff8000" Display="Boost" LogReference="Boost" RequestID="CALC" Eval="[MAP]-[Baro]" Unit="PSIG" MetricEval="[MAP]-[Baro]" MetricUnit="kPa" ResponseBytes="4" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Visible="False" LogHide="false" />
Don't know...
Rich
DataLog="N" and DataLog="Y" just indicates whether the item is logged by default, i.e., the checkbox in the display is checked. I suppose there could be some weird bug associated with it. I'm wondering if its OP 1.3 vs OP 2.0. I guess I'll try my OP 2.0 cable tomorrow. Thanks for considering.
willdatrill2007
Oct 9, 2016 09:01 PM
Pitside
Apr 29, 2014 04:02 PM
RS200Z
Jul 29, 2013 01:32 AM
