Evoscan Map Tracer
Evoscan Map Tracer
Anyone know if you change the maptracer so that it will output a table that has RPM on the Y Axis, and Logged KPA (Boost) on the X Axis. As it is setup after install, it has RPM (Y) and Load (X) but I am trying to build my ve-tables and I need KPA on the X axis. My load and KPA vary from 9-11 points apart. But I guess if I must I will just make the changes manually.
joedr
Nov 12, 2008 05:15 AM
evo4mad
Oct 25, 2007 04:14 AM
