Moving to England with plans on taking the Evo
Old Mar 24, 2013 | 10:10 PM
  #31
OldschoolEVO's Avatar
Originally Posted by spinner85
I'd like to see how you did that.
Also, It sounds to me like we'll need to install a rear fog light...
What about those of us running a TBE? The o2 sensors aren't throwing any codes. But I suppose it'd fail a visual and probably the sniff test.
I guess I may have to look into getting a lame-o catback installed for the time im in England...
The rear fog is as simple as running an inline switch to the passenger rear reverselight and putting a red LED in it.
TBE is no issue as long as you have some sort of cat on it for the sniff test. Of course there are some shady testers out that will pass it but it no big deal to me.
Originally Posted by fastyouth1313
Buying new headlights doesn't sound fun. I have the HIDs on my car.
Why would you have to buy new lights? To fix the headllights and foglight should cost no more than $50 total and a little bit of your time. And my lights are HID as well.
I'm bout to head out to work but can post pics of all my work later.
Old Mar 24, 2013 | 10:44 PM
  #32
spinner85's Avatar
you shouldnt have to buy new headlights, or even rewire your current ones.
I'm probably going to bake open the casing, and pull the amber lenses out. The turn signal bulbs are already amber. Done.
Then buy an oem rear fog light kit and wire it in. Either wire it into the switch for the front fog lights or wire in it's own switch. Done.
Old Mar 24, 2013 | 10:48 PM
  #33
spinner85's Avatar
True... that'd be much easier.
I have the Greddy TI-C which doesn't leave a place for me to put the cat back in... so for the time I'm in the UK, I'll just be running a cheapo catback.
Thanks for the help!
Old Mar 25, 2013 | 12:07 AM
  #34
To hell with pulling the light apart. I've read too many bad experiences with condensation later. Especially as much as it rains here. I chose the rewire because it simply looks better to me with lights reversed.
Old May 4, 2013 | 08:22 AM
  #35
vmrevo9's Avatar
Veteran: Air Force
well unfortunately i found out that our potential trip to england has been canceled. hopefully i can go somewhere else if not looks like i'll be a resident of georgia for a bit longer
therunningskier
European Forum
19
Jun 2, 2013 09:16 AM
GM4life
Jan 4, 2012 11:18 AM
tdubbz
15
Feb 26, 2010 08:24 AM
althemean
European Forum
Aug 2, 2005 07:42 AM
