Alpine Power Pack
Old Aug 15, 2010 | 04:13 PM
JordanS4's Avatar
Alpine Power Pack
Right now I have the stock speakers running off an Alpine 9857 Head Unit. I am looking to add a bit more clarity and power to my system so that it sounds good even with all the windows down (A/C doesn't work )
I stumbled upon this Alpine Power Pack when looking for 4 channel amps. It just plugs right into the harness on 1 end and the stereo on the other and bumps the system from 18W RMS x 4 to 45W RMS.
http://www.crutchfield.com/p_500KTP4...tp=35782&avf=N
My question is, will this be too much for the stock speakers to handle? Will it sound worse? I will eventually upgrade the speakers; should I hold off on this until then? I know the stock speakers are 15W RMS but I've been searching around on here and it seems like most people say putting an Amp on should go before speakers. Am I maxed out on the stockers right now with just a head unit? Doesn't seem like it but just want to be sure before I spend $120.
Thanks
Old Aug 16, 2010 | 05:45 AM
ov3rboost3d's Avatar
GET IT!!
I have the stock speakers and was really disappointed in the Alpine that I put in my car. After I added the power pack it is night and day. The stock speakers handle the power very well. I even put in some polk dbs, then some alpine dddrives but ended up putting the stockers back in till I get my sub in. The stock speakers put out more low end bass than anything else I tried. (have a lot of speakers laying around my garage)
I have been into car audio for 15 years so know the ropes pretty well.
Old Aug 16, 2010 | 12:43 PM
mogace's Avatar
A lot of people see it and wonder if it's worth the money. At my store, where I am an MECP installer, I put this on display but put the speakers behind the wood of the display pod. I have customers listen to another set up, then I have them check out the power pack. After they say how much better it sounds I inform them that the speakers they are actually hearing are behind the wood.lol
I put this in my pos Honda as well. It's awesome.
Old Aug 18, 2010 | 10:58 AM
JordanS4's Avatar
Great input guys thanks a bunch, I just ordered it!
Old Aug 18, 2010 | 11:10 AM
You won't regret it.
Old Aug 18, 2010 | 02:41 PM
CMoney's Avatar
off topic but do you know if this will work on a apline cda-9887?
Old Aug 18, 2010 | 02:44 PM
yes
Compatibility: The KTP-445 connects to any 2005 and newer Alpine headunit that has a black power harness. Please check with your Crutchfield Product Advisor to confirm compatibility.
Old Aug 26, 2010 | 09:52 AM
durangorider's Avatar
It is a great product. And then you will have more power down the road to upgrade your speakers.
Old Aug 26, 2010 | 04:59 PM
Don't bother unless you plan on adding a sub
Old Feb 14, 2011 | 03:49 AM
dfagod's Avatar
I read that the Alpine Power Pack requires the audio system to be rated at 15 amps, I thought ours was rated at 10 amps. Is this not true?
Old Feb 14, 2011 | 04:01 AM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
I have one and it has been working just fine, made a large improvement imo
Old Feb 14, 2011 | 04:14 AM
Old Feb 14, 2011 | 04:34 AM
FJF's Avatar
FJF
What, exactly, do you mean?
Old Feb 14, 2011 | 01:22 PM
mx4life85's Avatar
Where are you guys mounting this unit? I would presume it has to be mounted behind the head unit??
Old Feb 14, 2011 | 04:07 PM
dfagod's Avatar
From Crutchfield
"Note: The factory radio circuit needs to be a minimum of 15A. If it is not, a separate power and ground will need to be installed for the KTP-445."
