Alpine Power Pack
I see what you're saying. Most likely, the rated amperage is limited by the gauge of the wire. That comes into play when an amplifier is forced to draw more current from the electrical system, as in the event of driving low-impedance speakers.
The stock deck is the biggest limiting factor, equipment-wise. Replacing it with a current Alpine + PP is a win-win situation. MUCH better sound quality than an iPod running into a POS Boss amp, using itself as a system preamp, same amount of weight, and complete utility.
I find it funny that I purchased Type R component speakers all around and then have the Alpine HU send 18W RMS to them. I'm severely under-powering them and can't wait until the PP gets here.
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
the cables are long enough where i have the power pack behind my gauges that are where the stock radio location was, the radio is now in the cubby hole spot.
the instructions say to install the power pack and crank the radio as loud as possible, if the power pack shuts off then u don't have enough power. I never did this and haven't played the radio loud enough to ever have the pack shut down.
I'm kind of weary to turn the radio up as loud as possible just to "test" and see if the amp cuts off. Won't this harm my speakers not to mention my ears..LOL
We have installed them at our shop and on people running factory speakers. Well, its a matter of time before they blow up. For instance, We did one in a Silverado and the next day all four speakers were blown. This isn't like a big stand alone 4ch amp so keep that in mind with what you are expecting out of it
maybe lol thats why i didn't do that.
A crossover for what? An adjustable HPF is built into the deck and the speakers are configured from the factory. The input sensitivity of the amp is matched to the gain structure of the deck. As such, the final determinate lies with the user.
you can't begin to tell me you think that the HPF "x over" that is in one of those radios are doing justice.
Come on man.
and as far as dialing in gains to the speakers as you could with a standalone amplifier compared to the power pack is no where near adjustable to make the speakers last... factory speaker power ranges are usually designed for no more than 15watts.
Come on man.
Active variable crossovers, like the ones featured in the better amplifiers - Zapco being a good example - do not encounter the same limitations outside of added noise and distortion, though less so than the passives, but they are significantly more expensive. A x-over implemented in the digital domain is the best possible alternative, as it has no working drawbacks at all. Everything happens via an algorithm. With me so far? As such, a x-over in the Alpine is a lot better-sounding than the one in a typical car amplifier. Not only that, but it allows for control at one's fingertips. Win-win.
I should also say that not all Alpine decks technically operate in the digital domain. The lower priced units are analog, in a sense, as they're not DSP-driven, but the rest applies. In essence, the x-over is variable via a fixed network switched electronically.
1. It's safe to assume that the average Evo owner has a brain larger than an apple.
2. By tuning down the system gain, at times the sound will remain below the noise floor, rending the entire exercise useless.
3. The PP does have 2 fixed gain settings, so if this truly is an issue there is an option.
