Tuning questions
Old Feb 6, 2009 | 09:04 PM
Celica2EVO's Avatar
You need the gauge, there is a cable that you can make that will allow you to datalog via the AEM Wideband. Also, stick with the stock ecu, mellon is making over 600 hp on the stock ecu. He is a great tuner and does it all over emails. He will walk you through the whole process step-by-step.
unless you live by Buschur Racing (which you dont), or want to drop $1k plus for the AEM EMS, stock will work fine till you want to make huge power!
Old Feb 7, 2009 | 04:13 AM
Excalibur's Avatar
Ok, so when I wire in the innovative wideband sensor into the harness, what do I do with the aem guage to get everything working right?
Old Feb 7, 2009 | 10:59 PM
petersk2's Avatar
You don't need both an Innovate and AEM wideband, either one should work. I have the AEM wideband gauge and it comes with the sensor and a lead output to data log although I haven't used the data logging feature myself.
Old Feb 8, 2009 | 10:23 AM
Excalibur's Avatar
I just want one wideband, one bung, but want to have it used for datalogging, but at the same time, be able to see afrs on the gauge as well. I don't know how you would go about wiring that up or if it's possible.
Old Feb 8, 2009 | 11:08 AM
Celica2EVO's Avatar
The AEM UEGO Wideband comes with the 02 sensor, gauge, and wiring. All you have to do is hook it up and wire it in. As for the data logging, there is a wire on the wire harness made for that. you then have to buy an RS232 serial cable from radio shack and wire it in.
You do not need the Innovative and AEM. Just buy the AEM UEGO and when you get it shoot me a PM and I will help you wire it up and make the data logging cable.
Old Feb 8, 2009 | 11:47 AM
Excalibur's Avatar
Will do. I will be wanting to use the evoflash software to tune. That won't be a problem will it? I ask b/c you said something about a cable.
Old Feb 8, 2009 | 03:04 PM
Celica2EVO's Avatar
The data cable goes into the 9 port serial cable on your laptop. If you dont have one you will need a serial to usb adaptor. ECU Flash uses the tactrix cable which is OBD II to USB, this is a serial cable. You will use both at the same time. This cable transfors the data from the UEGO gauge to your computer.
Old Feb 8, 2009 | 03:23 PM
Shacochis06's Avatar
forgot the AEM wideband go with the Innovatic xd-16 wideband....better bang for the buck and it seems like you want to datalog so thats the way to go...PM mike@awd i know he keeps them and has ggreat prices
Old Feb 8, 2009 | 03:49 PM
Excalibur's Avatar
Alright, what if I want to be able to see the afr when I'm not logging and I'm just driving the car around daily? If I don't have a guage, how am I gonna know to check on my tune? Just do it when the weather changes, or I use different fuel, or whatever the case may be? Do I even need the gauge?
Old Feb 8, 2009 | 05:16 PM
the Innovative xd-16 is a afr gauge along with datalogging program (logworks i think its called) and the cable....
you really should be reading in the ecuflash section and understand what your doing before you make any changes to your tune....
Old Feb 8, 2009 | 05:23 PM
Excalibur's Avatar
I'm gonna have mellon help me with things when the time comes. Just looking into the hardware.
Old Feb 8, 2009 | 05:47 PM
Excalibur's Avatar
So the LC-1 wires into the oem ecu harness? Then the XD-16 hooks into that? Am I close? Any wiring diagrams? Pics of this setup. Just something to get a visual?
Old Feb 8, 2009 | 06:09 PM
Creamo3's Avatar
You're better off posting in the right section, as this doesn't pertain to tuning results. Look in the Ecuflash sub-forum or try searching for your answers.
Old Feb 8, 2009 | 08:09 PM
biglou's Avatar
i also have a question about tuning since we are all here..
What about if a EVO8 has a exhaust done but it doesnt have the O2 housing done , and the car is tuned for the exhaust , do i need to tune the car if i change the O2 housing ?
Thank you !
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
217
May 25, 2016 10:47 AM
Trale.Lewous
Northwest Region
Nov 2, 2011 09:35 PM
04evosonnn
Oct 26, 2010 06:08 AM
criptballer
19
Nov 19, 2009 11:07 PM
