Stock 2 liter, pump gas+meth, Red
Had a car come in today for just a tune.
A wide variety of parts on the car. I will list all that I can remember:
2006 EVO9
BR 3" turbo back
custom i/c pipes
manual boost controller (not sure of brand, never seen one before)
Stock 2 liter
Stock head
GSC cams
FP red
SS 02 housing
Ported exhaust manifold
K&N filter kit
Walbro fuel pump
SMC alky kit
FIC 850 injectors
AEM EMS, 3.5 bar map sensor, air temp sensor
No wide band
ETS 3" FMIC
The car came out good, he was also running Valero "93" octane gasoline which is the worst fuel you can buy in the country.
The car was tuned at 29 psi of boost. It was in the mid 20's here today and I use no correction on the dyno.
438 whp and 372 ft lbs of torque
Here is the dyno sheet:
I'd have liked to have tuned the car on better fuel and also suggested a larger FMIC, other than that the car worked really well and I'm impressed with the power it made. The car is used primarily for road racing.
2006 EVO9
BR 3" turbo back
custom i/c pipes
Stock 2 liter
Stock head
GSC cams
FP red
SS 02 housing
K&N filter kit
Walbro fuel pump
SMC alky kit
FIC 850 injectors
No wide band
ETS 3" FMIC
There was a problem with the boost controller on the car actually. The peak torque is where it finally hit 28 psi. The boost would not go lower and was slow to come up to that point.
Car very closely resembles the parts list from my old setup. Although he made a few ponies more. I made like 427hp on CBRD's dyno. There was still some left on the table, Chad was telling me to lean the car out more. I'm not surprised at this setup of yours making almost identical power.
This is not a slam against ETS but no the 3" core is not big enough. A 3" core from anyone is not big enough. In most cases I prefer to not even sell our 3.5" core. The 4" core and 4.5" core we sell as our Race and BFIC cores are what I recommend in every case.
This particular car had AIT's starting at 42 degrees, air temp was very low today, this morning it was -5 degrees here. I had our dyno fan running on high like always and the AIT's still climbed to 80 degrees on a single gear pull.
This is a road race car, can you imagine what it would do on a road course in 80 degree weather.
It has nothing to do with who built the intercooler, it is simply not enough to provide sufficient cooling.
I can't get any more politically correct than that, so keep the thread clean.
Glad you answered the fmic problems. I was about to ask myself what you suggested. I don't think the numbers are to bad. Would really like to see how much more you could get out of it fixing the issues the car had (mbc,gas,fmic).
GSC S1's or S2's?
GSC S1's or S2's?
Those are great numbers, and good to see because ill be running a similar setup on my car.
Also interested in knowing what itd run with better gas/mbc/ and fmic
And thanks for the heads up, because I was going to go with a 3 inch fmic
