FP Green on 91 oct
Old Mar 4, 2009 | 04:41 PM
  #61
Fknfstevo's Avatar
Damn. Thats sweet. And you have no cams? Thats insane. Before this i was having trouble holding boost. Like watching my guage, as fast as i would hit ~1.3bar it would go back down. And no matter how i turned the mbc always the same. My O2 to hot side gasket had a crack all the way throug it. I hope that was it. Also around the edges of the double flapper it looks to be rusted/cracked.
Old Mar 4, 2009 | 05:10 PM
  #62
06ssdevo9's Avatar
WOW, thats some good numbers. I can't wait to get a retune with the FP green I just recently installed. I have simliar mods with an exception of putting some cams in before the retune.
Old Mar 4, 2009 | 05:58 PM
  #63
EVOIXreno's Avatar
Originally Posted by Fknfstevo
Damn. Thats sweet. And you have no cams? Thats insane. Before this i was having trouble holding boost. Like watching my guage, as fast as i would hit ~1.3bar it would go back down. And no matter how i turned the mbc always the same. My O2 to hot side gasket had a crack all the way through it. I hope that was it. Also around the edges of the double flapper it looks to be rusted/cracked.
the white rabbit would hit 23 and taper to 20... then all of the sudden it would taper to 17...I found a leak in my intercooler piping... got some T-bolts all the way around and I am good to go!!!
Old Mar 5, 2009 | 03:56 PM
  #64
GRNCT9A's Avatar
"FP Green Ported Hotside,FP 18psi Wastegate, Ported Exhaust Manifold, AMS 3.5" FMIC Ebay DP, O2 housing and Test pipe, BBP Cat back Exhaust, Hallman Pro RX, Walbro 255 and PTE 780cc injectors!"
Thats almost the exact same setup as mine, just no 780s yet. I even have an AMS licp and ETS short route uicp..your only boostin 24psi and your making that much power, thats very good. Mustang dyno it'll probably be 350ish right?
Old Mar 5, 2009 | 05:23 PM
  #65
EVOIXreno's Avatar
360 370 depending!
Old Mar 12, 2009 | 01:41 AM
  #66
GRNCT9A's Avatar
Originally Posted by EVOIXreno
360 370 depending!
Not bad at all, I'm looking for 410-450whp on a mustang. Just need bigger injectors and a nozzle for my meth kit . Hopefully Lucas English isn't to busy, if he is I might have to hit up 4ws an see what he can do. I was thinking about gettin 680cc injectors, but since I'm going with meth. Do you think 720+cc would be ok? or are 680cc good but pushing it? sorry alittle off topic.
I just checked out 4ws's page. Seems like he knows exactly what he's talking about. I like his logging process, no other tuner has asked me to do that.
Anyways, I'm still very impressed with your numbers bro!! and your on 91oct! It's all in the tune
Old Mar 12, 2009 | 09:58 AM
  #67
EVOIXreno's Avatar
thanks...680cc might be pushing it! i'm at 78% idc
steveliu30033
Jan 8, 2017 10:04 PM
theblackbeast11
39
Jun 9, 2015 01:53 PM
heyzeus11
Jan 11, 2012 03:17 PM
