Will I hit 350whp?
Old Mar 8, 2009 | 09:59 PM
VajEvo's Avatar
Will I hit 350whp?
Evo VIII
Is it possible to get 350whp?
Mods are:
Stock IX turbo
Hks 272 intake / Hks 272 Ex.
Walbro 255
Hks Intake cone w/Pipe
Full Xspower Intercooler pipe
XsPower Intercooler
TurboXs Mbc
Full Ebay TBE w/ Test Pipe
Ebay O2 Housing
Hks Bov
Thanks
Old Mar 8, 2009 | 10:11 PM
blueprint's Avatar
on a dynojet... maybe.
on a dynodynamics/mustang... probably 315-330.
Old Mar 8, 2009 | 10:15 PM
VajEvo's Avatar
Thanks for the quick reply.
So, if I run 720cc Injectors w/ E85
I should be on my way
Old Mar 8, 2009 | 10:23 PM
porsherules911's Avatar
if you are tuned at 23psi I think you will hit that number easy.
Old Mar 9, 2009 | 03:39 AM
jsdude's Avatar
i think that's an easy number if you have every bolt on and cams with a 9 turbo
Old Mar 9, 2009 | 05:56 AM
JakeTheVIII's Avatar
Very possible. Especially on E85
Old Mar 9, 2009 | 06:54 AM
EvoDom's Avatar
i did 371 awhp on a dynojet @25psi with full bolt ons, similar to you, but i have an o2 dump abd some others.
very possible depending on the tune
Old Mar 9, 2009 | 09:19 AM
need4spd06ix's Avatar
i did 353 hp and 350 tq and my mods r ams tbe and licp,ets 4"fmic,k&n, hallman mbc@24psi with stock cams and fule pump . tuned by ivey
Old Mar 9, 2009 | 09:51 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Check the sig if I can do it on a 05 VIII turbo then a IX turbo will get you were you want to be with no problem.
If you use E-85 you might have to go with a double pumper and possible bigger injectors and you will well surpass the 350 mark
Old Mar 9, 2009 | 10:22 AM
sslevo's Avatar
A 255 lph and 1000cc injectors is the setup to have on E85 and the stock turbo. I would think 360-380 is easily doable on E85.
Old Mar 9, 2009 | 10:40 AM
aka03's Avatar
you wont need e85 with a good tune you will hit it.. turn the boost to like 22 maybe 23 you should be good.
Old Mar 9, 2009 | 02:35 PM
Wickedwhite8's Avatar
I think you will be there. good luck. post results
Old Mar 9, 2009 | 03:26 PM
VajEvo's Avatar
Thanks for all the quick reply.
Need to put on my intercooler and cams.
Will post up my result as soon as I get on a dyno
Old Mar 10, 2009 | 10:58 PM
guapoholic's Avatar
Atrocious punctuation..
Old Mar 11, 2009 | 06:58 AM
whats that supposed to mean "then my mivec went baaaah" dont be a hater!!
