574whp Stock block 92 octane 3586
Old Apr 26, 2010 | 08:07 PM
  #61
R/TErnie's Avatar
Aaron, whats the minimum amount of boost you can run with that wastegate without creep to 8500?
edit: 2.2L with the 3586.
Old Apr 26, 2010 | 08:12 PM
  #62
mrboost05's Avatar
^ thanks i am going to shoot for 500-550 on pump how do you like your magnus v5 did you see good results with it.
Old Apr 26, 2010 | 08:16 PM
  #63
R/TErnie's Avatar
The magnus v5 rocks.
https://www.evolutionm.net/forums/ev...s-v5-omfg.html
Old Apr 26, 2010 | 08:34 PM
  #64
BLKCarbonEVO's Avatar
Originally Posted by R/TErnie
+10 Magnus v5 FTW
Mikey
Old Apr 26, 2010 | 08:37 PM
  #65
JohnBradley's Avatar
23psi. On a 16psi spring and a 2.0l with the 38mm it would run 16 pretty much the whole pull with maybe a pound of creep...maybe.\
2.2 wouldnt run under 23, it would hit 16 and be to 20 by 6500 and then level at 23 by 7500 or so. I'll find one of the dyno files and see precisely.
aaron
Old Sep 27, 2010 | 10:59 PM
  #66
lillev23's Avatar
What do you think your car would have made on the stock motor with e85 on the hta86?
Old Sep 30, 2010 | 11:08 PM
  #67
Assuming it had the fuel system at the time and I was just adding in timing out the top, probably another 40whp or so and still keeping the torque down (at 29psi). This was done at 29psi and I had ran it to 32 on the street once or twice without knock.
I would think at the most maybe 640 at 33psi or so on E85?
Aaron
JohnBradley
Apr 16, 2015 08:02 AM
JohnBradley
Jan 11, 2014 07:50 PM
JohnBradley
May 1, 2013 11:58 AM
JohnBradley
Dec 22, 2012 03:39 PM
JohnBradley
Apr 9, 2012 11:29 AM
