E85 Fpred 532hp/478tq...
Subscribe
Jul 26, 2009 | 12:53 PM
  #46
hey derek give me a call when you get the chance I wanted to talk to you about tuning my car when it is done at AWD. And I wanted to ask a few Q's
Reply 0
Jul 26, 2009 | 01:45 PM
  #47
wish i had e85 local, good #'s man
Reply 0
Jul 26, 2009 | 02:17 PM
  #48
Quote: there you go...
Thanks man and congrates on the numbers...
Reply 0
Jul 26, 2009 | 02:24 PM
  #49
Nice numbers
Reply 0
Jul 26, 2009 | 02:34 PM
  #50
Quote: After maxing out the fpgreen and running a best of 10.7 @ 128mph, i decided to move on to the Fpred. Here are the results.
Full Mod List
Buschur intake and piping
Ets 3" fmic
Megan tbe
Tomei 260 cams
Ported intake mani/tb
Ported exhaust mani
Epm o2 dump
Precision 1200cc injectors
Fuel rail
FPR
Buschur double pumper
Stock motor
Stock Ecu
32-33 psi.
Are you using the "standard" FP Red with 63 mm compressor inlet, or the 80mm version?
http://store.forcedperformance.net/m...e=Lancer-Turbo
Reply 0
Jul 26, 2009 | 02:57 PM
  #51
NICE Numbers!!!
Reply 0
Jul 28, 2009 | 06:33 AM
  #52
Quote: Are you using the "standard" FP Red with 63 mm compressor inlet, or the 80mm version?
standard fpred
Reply 0
Aug 9, 2009 | 07:45 AM
  #53
Do you fellahs think 1000cc injectors would suffice for running a FP Red on E85 with the double pumper? Thanks.
Reply 0
Aug 9, 2009 | 11:29 AM
  #54
Quote: Do you fellahs think 1000cc injectors would suffice for running a FP Red on E85 with the double pumper? Thanks.
nope, you will need atleast 1200's, a fuel rail, and a regulator I believe. Well that is atleast what Diiirk was running.
Reply 0
Aug 9, 2009 | 01:00 PM
  #55
Quote: nope, you will need atleast 1200's, a fuel rail, and a regulator I believe. Well that is atleast what Diiirk was running.
I'm fine with the 1200cc injectors if that is indeed the case but the FPR is a part that I really do not want to purchase. In this case, I do hope that you are wrong.
Reply 0
Aug 9, 2009 | 01:25 PM
  #56
Quote: I'm fine with the 1200cc injectors if that is indeed the case but the FPR is a part that I really do not want to purchase. In this case, I do hope that you are wrong.
depends on the power level, but i can tell you that these numbers would not have been possible with 1000's and double pumper. you will definatly run out of fuel before you can reach 500 hp. the other thing is you can run double pumper and 1200's, but without increased fuel pressure, 1200's do not flow much more than 1000's.
Reply 0
Aug 9, 2009 | 02:27 PM
  #57
I'm assuming you're talking about static fuel pressure with a 1 to 1 boost reference?
Reply 0
Aug 9, 2009 | 11:32 PM
  #58
Quote: depends on the power level, but i can tell you that these numbers would not have been possible with 1000's and double pumper. you will definatly run out of fuel before you can reach 500 hp. the other thing is you can run double pumper and 1200's, but without increased fuel pressure, 1200's do not flow much more than 1000's.
OK. I understand. For my initial plans I just want to take advantage of the E85 and if I will eventually be limited by fuel when it is time to tune, I'm fine with that. I'll be tuned on the stock ECU and from my understanding 1200cc injectors are difficult to tune. Is this not correct?
Reply 0
Aug 10, 2009 | 03:42 AM
  #59
Quote: OK. I understand. For my initial plans I just want to take advantage of the E85 and if I will eventually be limited by fuel when it is time to tune, I'm fine with that. I'll be tuned on the stock ECU and from my understanding 1200cc injectors are difficult to tune. Is this not correct?
1200 are not difficult to tune. A couple of people are on 1250 fics including myself. jid has tuned 1450s on stock ecu.
Reply 0
Aug 10, 2009 | 06:33 AM
  #60
Quote: 1200 are not difficult to tune. A couple of people are on 1250 fics including myself. jid has tuned 1450s on stock ecu.
That is great information to know. Thanks.
Reply 0
Subscribe
