Olmoscd's 3076, 93 octane 495whp!
Christian is one of our good customers from Fail, NC. We got a call that he would be in the area and wanted to get some work done. Last time one of the guys was in, they picked up some Powerflex front and side motor mounts up for him as he was trying to stiffen up the driveline in hopes to improve his launching at the dragstrip.
Christian came in running 23psi on pumpgas with many supporting mods, too long to list.
What I think I can remember is 1050cc injectors, MAF Translator with GM 3" blow thru MAF sensor. AFI 3076 turbokit.
Once I was able to reverse trace the load cells being traveled from the lowering of the maf signal from the translator blow through, we got a handle on the tuning, richened it up and worked the mivec tables, boost, ignition timing, and some custom tweaks in other areas, here is the result:
Scott, I'm blushing.
You beat me to posting the dynosheet! Check your email, btw.
No meth. Injectors are FIC 1050's, boost was spiking to 31.x (I think) tapering. The soft spring in the Forge MBC was maxed out at 29 PSI, the stiff spring started at a 31PSI spike. I need an advanced EBC that will hold 30 PSI consistently.
This is also not an HTA unit. .63 A/R.
You beat me to posting the dynosheet! Check your email, btw.No meth. Injectors are FIC 1050's, boost was spiking to 31.x (I think) tapering. The soft spring in the Forge MBC was maxed out at 29 PSI, the stiff spring started at a 31PSI spike. I need an advanced EBC that will hold 30 PSI consistently.
The red is a good turbo, but we only see 420whp out of it on pumpgas.
Nice numbers Christian. I can't wait to see what mine can do with the turbo kit I put on before leaving. Of course now I have a whole new round of mods to do!! LOL Still not up there with you though.
Josh
Josh
