a sad day today at the dyno. pls help.
why not go back and have them check the mechanical items you listed to rule those out or get fixed? i would assume by Al mentioning that there may be mechanical issues that your car is not producing the numbers he would expect. its all speculation at this point... what did he think your car should have produced for numbers?
That's not horrible by any means...I'm talking out of my *** BUT given that you are making 385 tq and 330~ whp it seems like the turbo runs out of steam up top, which is NORMAL for a stock 8 turbo. Dyno charts would help but this seems to be the issue, just need a bigger turbo to get the big numbers
If you look at 96% of the stock turbo dyno sheets any stock Evo turbo will taper (run out of steam) as the RPMs increase. Most stock turbos taper to around 19-20 psi at redline, its normal.
Sad Day? Are you serious?
Are you new to modifying cars?
IT's a process, you fix the problems and move on. An evo 8 turbo will make 380-390 in the summer time no problem, you have to figure out what is wrong correct it and go back on the dyno.
Engine needs to be checked, boost leaks, mods done by previous owner etc.
Alot of times there are problems with the cars when they come in and it has nothing to do with the ability of the tuner.
Sean
Sean
[QUOTE=olmoscd;7347679]Easiest thing to do is blame it on the tuner. Let's go with that.
[/QU HAHAHAHAHAHA that's probably your answer...Usually when the turbo starts to go bad it tends to smoke really bad like white and grey is it doing that?It could be your turbo that it's starting to die slowly...Why dont they check the car out on monday instead of thursday what if u really have a major problem expecially running meth like that be carefull u dont ruin anything..if u want ill sell you a almost new 9 turbo for a good deal just pm me....
[/QU HAHAHAHAHAHA that's probably your answer...Usually when the turbo starts to go bad it tends to smoke really bad like white and grey is it doing that?It could be your turbo that it's starting to die slowly...Why dont they check the car out on monday instead of thursday what if u really have a major problem expecially running meth like that be carefull u dont ruin anything..if u want ill sell you a almost new 9 turbo for a good deal just pm me....Sad Day? Are you serious?
Sean
Sean
[QUOTE=IDRINKV8'S;7347721]
Well I would love to go there monday but work is not lettin me..thursday is my only day off..it is a little harsh, but I can agree with sean ivey's recommendations..he does know what he is talkin about.. My next door neighbor with a red evo 8 was actually tuned by sean ivey and made nice numbers wid the stock evo turbo..he did inform me of sean ivey tuning.. But Im hardly new nor old in this game.. I had a subaru before that made 378whp with no meth before but was stolen so didn't really know what it means when sumthin goes wrong like the turbo goin out..only got to enjoy it for 2 years..I jus had my evo 8 for a year and it is a similar but difficult process because the two are almost alike but so differnt in a lot of ways also in terms of parts used..but thank you for your concern.
Hey guys - big shout out to OP and my customer Tristan and also to Sean Ivey for pointing out the obvious
Cars with 70 k plus hard miles will start to develop problems
Back in '03 when we started to tune Evos they were ALL brand new so when we added on all stage IV mods and ran race gas we knew the stock turbo is good for nearly 400 TQ and the cars were nearly brand new
Now some of the '03 cars have 8 years of driving and use on them
This is what happend in this case - (I will share this data as we are all here to learn)
The customer and OP felt his car was not running right and had made a couple of mod changes and had his clutch changed so he wanted a boost leak test whioch we did with our amazing smoke testing machine and found no leaks or any kind
Obviously since he was very in touch with his car he felt and knew there was a boost issue which is why he idenifiied and requested the boost leak teat which was a great idea
When I got the car on the dyno and saw how lethargic and weak it was comming on boost and how low the peak boost was I suspected an issue with his boost controler
My next diagnositic issue is to clamp off the hose going to the wastegate which would achieve maximum boost that his turbo / wastegate combo could produce
Claping the hose had only a 6 whp effect on the car and the boost level was far lower than expected
Rather than dick around with changing his wastegate actuator which may be bad and running up service charges I offered to provide the OP for FREE a known good turbo which previously hit 400 whp and just swap in the known good turbo / wastegate combo
At this point I can not be 100% sure that the turbo or wastegate is his problem - however, based upon my years of tuning and dyno experience on the stock turbo I feel it is very likely that one of those two is the cause. I say this based upon the sound, how the car reacts when you turn up the boost, the knock count being very low and the very lazy spool up.
An important lesson to take from this is that when tuning the most important thing a tuner can do is tell you when the car is NOT running properly and ler you KNOW that you HAVE a problem. A good tuner will not let a car with mechanical problems leave now will he try and push it harder with more agressive tuning to make up a mechanical short comming.
As the cars are getting older, passing through more hands and being more heavily modified diagnosis and problem fixing is going to become more and more a core part of the tuning process.
I am looking forward to seeing how the new turbo and w/g combo will effect the car when we install it on thursday.
I would like to see your car closer to 390 - 400 TQ and 360 whp
Al
Al
