Tomei Arms Round 2!!!!!
Old Aug 20, 2009 | 02:08 PM
  #31
CBRD's Avatar
Originally Posted by leecavturbo
nice run.
sounded as tho the clutch takes half a second to fully bit after you change gears?
i wonder what cbrd will say to that who don't rate this turbo
not sure what you are saying-
congrats on the good numbers...
again, im curious what another one of these would do with more mods!
cb
Old Aug 20, 2009 | 02:32 PM
  #32
aka.ralliart15's Avatar
please don't start arguments guys, I respect Chad, CBRD and the BBK Full, I wanted to have fun at the track and I did...my friend is gonna go on E85 and the tomei real soon, ill let you guys know.
Old Aug 20, 2009 | 02:42 PM
  #33
leecavturbo's Avatar
no hating chaps. just chad ran one with less than expected results
Old Aug 20, 2009 | 02:46 PM
  #34
wreckleford's Avatar
Where are you guys buying your Tomei stuff from?
Old Aug 20, 2009 | 02:51 PM
  #35
ASAPPerformance's Avatar
We have the Tomei Arms turbos in stock and we also have a lot of Tomei Parts, let us know what you are looking for Im sure we can help.
Old Aug 20, 2009 | 03:10 PM
  #36
Thats ok, different set-ups will yield different results.....btw I think that the Tomei will shine a bit more with smaller cams, like 260/272, smaller 272's or even 260/260....they seemed to work really well for diiiirk and others that I've talked to.
Old Aug 21, 2009 | 09:46 AM
  #37
Cali2MDevo8's Avatar
Registered User
Possibly a smaller IC will clear some of that lag up. Peak TQ isn't til almost 5K RPM. Or maybe ecu controlled boost
Old Aug 21, 2009 | 10:51 AM
  #38
pls1968's Avatar
Wow Luis Congrats to you and Cwill on the numbers and times. Gotta love not having to shift into 5th in the 1/4 mile.
Old Aug 21, 2009 | 01:42 PM
  #39
That's true the 4.5" flows a lot of air....
Thanks buddy and it certainly is an advantage....how that Red treating you?
Old Aug 21, 2009 | 10:50 PM
  #40
RainesEVO's Avatar
The ARMS does not like big cams for sure. I have Cosworth 280 IN/ 272 EX, and numbers are not as good as another car with similar mods running straight 272s (same dyno, same tuner so the numbers should be comparable). Once I get a 272 IN cam installed and retuned I will post results.
Old Aug 22, 2009 | 12:33 AM
  #41
Levar's Avatar
Veteran: Army
That is pretty interesting. I currently have the GSC 264s but was considering either the Kelfords or GSC S2s. I might just roll with these to see how things turn out as the intake has a 10.8mm lift and the exhaust has a 10.2mm lift. Thoughts?
Old Aug 22, 2009 | 07:15 AM
  #42
CWiLL's Avatar
I think they like an even smaller cam
  #43
CWiLL's Avatar
Stick with the Smaller cam for now.
Old Aug 22, 2009 | 08:15 AM
  #44
Levar's Avatar
Veteran: Army
I sure will as it will save me about $500 for the Kelfords and $220 for the springs/retainers. Great!
Old Aug 22, 2009 | 10:37 AM
  #45
Thats some good saving right there lol....I guess my cams are more geared towards a bigger turbo from what I've seen. Good luck with whatever you decide to do.
